Old 27-Sep-2005, 14:47   #1
neil748r neil748r is offline
While we\'re talking quickshifters . . . . . .
anybody using one of these shift levers (see attached pic)?
Ideally would like a copy of the set-up instructions or whatever that came with it.
Also need all the blurb that came with a Techtronics QSLU2 quickshift - installation, set-up, wiring schematic etc etc.
Thanks guys,
Neil.
Old 27-Sep-2005, 14:52   #2
Felix Felix is offline
Neil, that looks like a copy of the official Corse unit. There is a procedure in my RS race manual, I believe. I'll check tonight.
Old 27-Sep-2005, 14:57   #3
That's the latest JHP/Techtronics lever, same as I have on the 999
Old 27-Sep-2005, 15:08   #4
Thanks Felix, but I don't think it works in quite the same way as the Corse part. Corse part uses Hall Effect Sensor and the JHP part uses a simple switch so set up may not be the same - I could be wrong though!
JPM, did any set-up instructions come with the lever? if so, any chance of a copy?
Thanks again fellas,
Neil.
Old 27-Sep-2005, 18:10   #5
Crunchy Crunchy is offline
Crunchy's Avatar
That is the Techtronics shifter. If you ring John Chalton on 01295 714144 he will send you what you need. A VAP (Very helpful chappy).
Old 27-Sep-2005, 18:21   #6
My Q/S was fitted by JHP, so no instructions, but I don't think there's anything other than a simple on/off switch on the lever, the box does it all I think...
Old 27-Sep-2005, 18:40   #7
Yeah that's what I thought, although I think the switch is adjustable for actuation pressure.
Crunchy, thanks for the number. Unfortunately John no longer deals with Techtronics - if he could've helped he would've though.
Cheers, Neil.
Old 27-Sep-2005, 18:43   #8
You might be right there, I'd give JHP a call... it's their level after all (well Techtronics) I'm sure they'd be more than willing to help
Old 27-Sep-2005, 18:44   #9
Crunchy's Avatar
Just a sec. I'll get my magnifying glass.
Old 27-Sep-2005, 23:44   #10
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
Looks like good stuff. Im on the phone in the morning.
