Old 28-Sep-2005, 12:21   #1
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
Blowing Exhaust
While changing the oil and filter on the 749 I noticed that the rear pipe was rather tarnished and in need of a bit of a polish. While warming the bike before changing the oil I also noticed that there is a small amount of exhaust gas leaking from a joint in the exhaust about four inches from the rear cylinder.
Is this something that I should worry about?
The bike has about 5,000 miles on it and was purchased new by me with the Asymetric Termi fitted
Old 28-Sep-2005, 15:02   #2
Got a small leak on mine too as discovered after cleaning at the weekend, just from the joint between the two pipes, personally I'm not that bothered about it
Old 28-Sep-2005, 22:05   #3
Carbon749's Avatar
Mood: I own a flame thrower
Push fit pipes and spring clips, will leak a little. Nothing to be over woried about.
If it gets worse or you are concerned take it apart and wipe a little silicone sealant in to the joint when you build it back up.
Old 28-Sep-2005, 23:34   #4
sbwells's Avatar
Thanks mate that's what I thought.
I might pull the exhaust off and give the whole thing a good polishing and reassemble with sealant
