Old 29-Sep-2005, 18:25   #1
BIG-G BIG-G is offline
BIG-G's Avatar
Mood: I started life with nothing and still have most of it left
Side stand lean
My 749 seems to lean at quite an angle compared to other bikes I've owned. Without the 50 mile trip tp my nearest dealer can anyone tell me if this is the norm.
Do they stretch the bracket or come loose
G
Old 29-Sep-2005, 18:57   #2
weeian weeian is offline
Mood: 2 for 1 mmm :)
This is normal Big - G, you can actually pull the bike over the stand and put the bikes full weight on it no problem, i do it all the time to manouver it around tight spaces, saves loads of time.
/ian
Old 29-Sep-2005, 20:46   #3
Stealth Stealth is offline
Bikes: 998R, Panigale S
Stealth's Avatar
.....and another one to think about is if you (or someone has wound up the preload). Back of bike sits higher and therefore the lean is greater.......
Old 29-Sep-2005, 21:26   #4
bike mad bike mad is offline
bike mad's Avatar
not much lean on the 2 I've been on. if you want I'll give you the number of degrees that it leans over, but it will have to wait till tomo ,
Old 29-Sep-2005, 22:51   #5
tricky tricky is offline
Mood: Need spares
The lean is much greater than most jap bikes. Always feels a little bit worrying when your leaning the bike over onto the stand from the right hand side, u start thinking is the stand down ?
Old 30-Sep-2005, 06:54   #6
Yep,and a few worrying moments on uneven ground.
Old 30-Sep-2005, 13:16   #7
BIG-G's Avatar
Thanks, I feel easier now.
G
Old 30-Sep-2005, 14:26   #8
BIG-G's Avatar
Me again, just had another look and it still looks well over. Height from inside barend to floor is 66cm with wheel straight. Can anyone check this for me please.
G
Old 30-Sep-2005, 16:40   #9
Just measured mine,...69cm.
Ohlins forks with a fair amount of preload.
Old 01-Oct-2005, 19:17   #10
mark749s mark749s is offline
mark749s's Avatar
just measured my 749s and it is 68 Cm
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:44.
