Old 30-Sep-2005, 14:05   #1
iang iang is offline
iang's Avatar
Best way to bleed brakes/clutch ???
Well, I have just fitted my new Cycle Cat bar risers and after a lot of adjusting they look about the same both sides now !!
The only problem is that after much cursing and swearing I cannot seem to get a brake or clutch lever.
The original reservoirs had to be removed and replaced with Brembo GP types, the fluid is in them but I just cannot seem to get the fluid to come to the bleed nipples.
I have bled brakes countless times before and sometimes they are a real pig but I just cannot get this to work.
What is the best way to do this.
Suggestions please ( Helpful ones !! )
[Edited on 30-9-2005 by iang]
Old 30-Sep-2005, 14:08   #2
Perseverance!!! There have been a few threads on this - worth a search.
Old 30-Sep-2005, 14:10   #3
HW HW is offline
Brakes are not so bad to bleed because the pads do stop when they reach the disk and so the fluid has to go somewhere (else). I fitted a tecmoto modified clutch slave to my ST2 some time ago and it was a bitch to bleed as it tends to operate the clutch (a little) I guess rather than find another route.
I watched a mechanic bleeding a rear brake once and he used a large syringe full of fluid. He took the reservoir off, tipped it upside down and removed it from the pipe, stuck the syringe nossle in the tube and forced fluid through (bleed nipple cracked open a touch). I was surprised, but it seemed to work and was a darn sight quicker than the way I normally do it.
Old 30-Sep-2005, 14:18   #4
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
Originally posted by t5mission
Hi all,
Ok so last night I decided to clean up and check the brakes on the 996. Unbolted the hoses removed the calipers and master cyclinder and waisted a can of brake cleaner. The pads had tonnes of meat on them but were green stuff (YUK).
I knew I could replace them till the weekend but wanted something do last night, so got out the wok and the washing powder and boiled them for 10 mins. They came out like new still green but look new.
After cleaning and checking everything and bolting everything back together with new copper washers I was on the the hard job of bleeding. Cracked off the caliper bleed nipples and got some tube and a couple jars (I prefur the old fashion way) topped the system up with Automek SBF pumped it a couple of times and kept topping it up.
Next thing was to hold the lever in with a rubber band and go for a coffee. After about 20mins went back to the bike and closed of the bleed nipples. Topped of the fluid and pumped the lever to my suprise there was presure there straight away. Checked each caliper for bubbles the bleed the master cyclinder and "jobs a goodun".
I now have one finger breaking but will get some decent pads at the weekend but at least thats only a 20min job.
I have never had brakes go this easy, is it a brembo thing or just blind luck who knows. Anyway hope this helps someone at some stage when you can't get any presure.
Sorry didn't know how to link a post.
Old 30-Sep-2005, 18:04   #5
khu996 khu996 is offline
khu996's Avatar
Got them on mate? Lets have some more pics!
I've had the same problem before, and also used a syringe, but in a different way:
Attach a syringe (via a piece of clear tubing) to the bleed nipple on each caliper, and suck the air out, drawing the fluid through...worked really well for me!
How do the bars feel? What position have you got them in?
Old 30-Sep-2005, 21:01   #6
iang's Avatar
How about a laugh everybody !!!
The best way to bleed the brakes after fitting bar risers is to take the reservoirs off that you have just fitted and remove the bungs in the bottom, this tends to help the brake fluid to come through !!!
Stupid B*****d that I am.
Khu, they are a tw*t to fit, I have not got them adjusted yet as I have just come in from doing them and my friday night curry has just arrived, I will let you know tomorrow sometime.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:13.
