Old 03-Jul-2013, 23:59   #1
Trumpet Trumpet is offline
Bikes: Triumph Speed Triple/DD 620/
Mood: It's a grand life if you don't weaken
Idle / tickover problem
Think I have got to the bottom of why the bike would not idle properly, I took the carbs off and thought I should check the pilot jet. One has a spring and a tiny 'O' ring, the other has bugger all, just the needle itself.
So two questions; Will I have to order through Ducati dealer (hope I can get one in time for Cadwell)? The second question is when I have got all the bits, does anyone know how many turns out of the pilot jet I should try to start with?
Old 04-Jul-2013, 06:12   #2
3 full turns out. Be ok for Cadwell anyway as the throttle is pinned.
Old 04-Jul-2013, 18:09   #3
milesaway milesaway is offline
Bikes: 900ss 600ss xr400
milesaway's Avatar
call moto rapido 01962 877998- the only duc dealer who's never made me wait ages for bits and/or I think this is the number of a place i got a carb seal kit from 01618 328646
Old 04-Jul-2013, 22:50   #4
Mark I may still have a set of scrap carbs that could well have a idle mixture screw in them, I know Jimbers needed a few parts off them at Donington a few years ago. I'll have a look over the weekend
Old 05-Jul-2013, 11:36   #5
Just found the carbs that Jimbers had the fuel T-piece from
Both Pilot mixture screws are like new as are the springs, but no O-rings, not sure what happened to them.
If anybody ever needs an air cut off valve these will probably do the job
http://www.ebay.co.uk/itm/Yamaha-TRX...item2a21501521
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:04.
