Old 01-Oct-2005, 11:09   #1
nicks nicks is offline
Leaking exhausts
Morning everyone, as the sun is shining today you are probably all out riding some lovely Ducatis!
Anyway to my question -
Just fitted a set of Micron Carbon cans and have a few leaks to the left hand link pipe where it meets the orginal Ducati down pipe.
Is it ok to use a jointing paste as you would with a car exhausts system??
Nick
Old 01-Oct-2005, 20:30   #2
Carbon749's Avatar
Mood: I own a flame thrower
Best thing is silicone sealant ..... stays flexible even with the heat of the exhaust system.
Old 02-Oct-2005, 13:02   #3
Martini Martini is offline
Martini's Avatar
Mood: what a day, a year, a life it's been
I've used normal exhaust sealant. Seems to be fine. Be careful not to get too much of it on the outside of the pipe - it looks awful when it dries. It can also make getting the pipe off later a bit of a struggle!
Old 02-Oct-2005, 16:11   #4
see what you mean about the exhaust sealant
well it has done the job but now it's had a blast around an got really hot the sealant has all come out and now needs cleaning off!
Old 03-Oct-2005, 11:04   #5
sbwells sbwells is offline
sbwells's Avatar
Mood: Bring the noise!
Nicks. Shazzam recommended Permatex Ultra Copper RTV Hi-Temp Silicone sealant. This looks like the type of thing for the job if you are using silicone.
I had the same problem with standard pipes and the termi asymetric muffler on my 749s. I used standard exhaust joint sealant and the problem is now solved.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
