Old 08-Oct-2005, 16:20   #1
flanagaj flanagaj is offline
Changing timing belts on 748
This question has most likely been asked numerous times but is it really that hard for a novice mechanic to change there own timing belts and do you need any special tools ?
PS - Do stainless steel clutch springs make any difference to stock steel ones ?
Old 08-Oct-2005, 16:42   #2
http://www.ducatisportingclub.com/xm...3429#pid114740
Obviously, stainless springs are more attractive with an open clutch cover. The problem is (often) that making the same size coil from stainless material gives a slightly different spring stiffness - so you may need to use a slightly different height clutch plate stack to get the same preload.
