Old 17-Jul-2013, 22:16
dkbunny71's Avatar
dkbunny71 dkbunny71 is offline
Cool headstock bearing help
can anyone tell me are there any other models that use the same headstock
bearings as my 94 600 ss as the prices i am being quoted are ridiculous
Old 17-Jul-2013, 23:05
600SS shares the same bearings as
750SS, 750SSie , 900SS, 900SSie
M600, Early M750 and Early M900
about £30 a set, and yes I have fitted 600SS Yokes into a M600 Frame
http://www.ebay.co.uk/itm/Ducati-900...em1e 77991e1e
http://www.ebay.co.uk/itm/Ducati-Mon...em3a 80914ee0
Old 18-Jul-2013, 23:19
dkbunny71's Avatar
Cool thanks
thanks mate just wasn't sure had a thought they might be the same
but better to be sure
thanks again
Old 21-Jul-2013, 23:10
(Old post from Elsewhere I uncovered)
I'm trying to find out some spec's for the bearings - I simply took my old ones to a bearing stockist and they replaced them with identical SKF taper rollers for £12 each!
Here are some good tips I've found:
"remove fairing, get the front end supported(I have an engine stand), remove guard, wheel, forks etc. Ashamed to say I used a mallet and substantial screwdriver to loosen C-ring but managed not to mark it. You might want to mark where your forks are in the yokes before dropping them out, and take a note of the order that locking nut, washers etc come out in.
Haynes is okay as a guide for this though from memory the pics aren't particularly instructive."
__________________________________________________ __________________________________________________
"Just removed the bearings off my T8 the bottom inner race I removed with a dremel with the little cutting disc attatchment cut through as far as possible without touching the yoke.
then with a small sharp chisel place in the groove and tap with one hard blow this splits the shell and it then pulls free.
make sure you have the yoke on flat but shock absorbing surface I used a bit of hardboard on the metal work bench.
hope this helps"
"Outers are obviously are the problem in the head stock.
Inners in the steering stem were the other one I remember! and the worst one for me - wish I'd of know about the Dremmel trick as I say a mate at work used an Oxy torch and burnt my lower one off - the heat was a bit drastic to say the least.
I simply used a long tube to remove the outers - not much of a lip to work with in the frame - I recall it took a long time being patient and working around the bearing evenly.
Assembly really was easy - outers in the freezer overnight and then hairdrier in the frame tube, no problem there.
Inner lower bearing needed a tube to press it right the way down the stem - all pretty straight forward really.
I would not bother trying to ABSOLUTELY seat them either as riding the bike and bedding the bearings in finally seemed to entail a few bearing adjustment sessions - but was fine in the end.
Be methodical - use a bearing specialist (not a bike retailer) and I'm sure you will be fine."
"The numbers are:
SKF:639174
SKF:639172
With thanks to user Jasper over at the DSC website; photo also
Cheers - Frank
NB - Cant confirm sizes but just seen a post stating 26 X 52 X 15
Postal Recommendations:
1) "got a set sent from bike bearings mega fast postage highly recommended "
2) I used these guys for some pretty specialist needle bearing & they came up trumps:
Motion Industries,
Unit 2,
Bracken Trade Park,
Dumers Lane,
Bury,
Lancashire,
BL9 9PE
Old 25-Jul-2013, 23:36
miintsauce miintsauce is offline
We-Moto do an All Balls bearing kit for around £30
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:16.
