Old 18-Jul-2013, 20:34   #1
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
Fitting a fairing bracket to a monster
Is there any reason why I shouldn't drill and tap the headstock to fit an ally fairing bracket?
Also, if I was to fabricate an ally tank, is 1.5 mm thick enough?
Steve
Old 18-Jul-2013, 21:05   #2
numbskull numbskull is offline
Bikes: 848 Evo ‘Pikes Peak’, 748S, 200 Single
I made my ali tank out of 1.5mm material.
It was fine... I think!
Old 18-Jul-2013, 21:08   #3
Grey area, the drilling of frames is usually frowned on
What happens if a technical inspector decided the drilling of the headstock has weakened it and in their eyes made it unsafe to race
Accepted methods are welding or clamping of a bracket to the headstock
Old 18-Jul-2013, 21:09   #4
Well you did crash test it
Old 18-Jul-2013, 21:45   #5
Thanks for that. When I was sparkying up the car factory, we were only allowed to drill the steel supports/rsj's if we tapped them and fitted a bolt. That was considered replacing the steel and not considered as weakening the support.
As its subjective, and scrutineers have the final word on race day, it's not worth chancing it.
Ally to steel? I guess that'll be a clamp then.
Old 18-Jul-2013, 21:47   #6
Excellent. Ta
Old 18-Jul-2013, 22:18   #7
Thanks Kev!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:12.
