Old 19-Jul-2013, 22:55   #1
Cliffy858 Cliffy858 is offline
Newbie
Bikes: 748s, KTM 250exc
Cliffy858's Avatar
748 chain length
Hi, I've just bought a new jt sprocket carrier and intend to run both 14/40 and 14/42 combinations to see what I like best. However is this possible to do with the same length chain and what length shall I order. I think it will be a 98 link chain but I could do with some advice. Thanks
Old 20-Jul-2013, 00:38   #2
The difference between the two options is almost 9mm in the wheel position, so only just over half a link in the top and bottom chain run.
so 98 will probably be OK with both, but as I prefered to run my 748 on as long a wheelbase as possible I would probably go for 100 link, at least that way you always have the option to shorten the chain
Old 20-Jul-2013, 09:23   #3
Newbie
Cliffy858's Avatar
Thanks, I didn't realise that there is that much adjustment.
Old 20-Jul-2013, 16:33   #4
Fair bit of adjustment, only thing is when you adjust the eccentric that much it alters the ride height so then you have to adjust the rideheight bar. So get a reference before you start.
some use centre of the spindle to middle of the exhaust can or a sticker on the seat unit
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
