Old 15-Oct-2005, 03:45   #1
rob holmes rob holmes is offline
polishing exhaust
does anyone know whats best to clean up the bottom part of the exhaust?
Old 15-Oct-2005, 09:22   #2
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Long slither of rag wrapped around pipe twice, then a squeeze of Autolsolv,give it time and your'lle be able to shave in em. 4D
Old 15-Oct-2005, 11:18   #3
Crunchy Crunchy is offline
Crunchy's Avatar
Were do you get Autolsolv. Please explain the process a little more
Old 15-Oct-2005, 11:48   #4
Carbon749's Avatar
Mood: I own a flame thrower
[/quote]
Were do you get Autolsolv. Please explain the process a little more [/quote]
Autosolv is a metal polish, comes in a tube like tooth paste and looks a bit like tooth paste. Available in the UK from any high street car accessory shop.
Old 15-Oct-2005, 11:53   #5
Crunchy's Avatar
Do you put the Autosolv on first or the rag and then rub the Autosolv into the rag. Do you then heat the exhaust What's the process??? Is there a website where I can order online as I'm in Germany
[Edited on 15-10-2005 by Crunchy]
Old 15-Oct-2005, 12:15   #6
Carbon749's Avatar
Hi,
Mis-spelt the name, it's actually Autosol and it's german.
check out this web site, may help
http://autosol.com/
When I use it, I rub it into the metal with my fingers and then use a cloth. Swap cloths to a fresh clean one to buff to a shine.
Old 15-Oct-2005, 13:17   #7
Does autosol get the discolouration off or do you have to use a more abrasive method first like fine emery cloth?
Old 15-Oct-2005, 13:54   #8
norty mart norty mart is offline
Mothers MAG & ALUMINUM POLISH is the stuf the show Harley boys use, polished up my 996 cans to a chrome-like finish, did both in about an hour and without the black fingers Autosol leaves you with!
...also leaves a coating that stops the finish dulling.
Only place I've seen it was West Coast but they've now gone, Google search should come up trumps - was about £6 a tub but lasts for ages.
Old 15-Oct-2005, 16:59   #9
Crunchy's Avatar
What if you have rust showing though?
Old 15-Oct-2005, 17:01   #10
Carbon749's Avatar
Thought the pipes were stainless steel
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:41.
