Old 18-Oct-2005, 18:55   #1
iang iang is offline
iang's Avatar
Quick question , someone ?
I have just fitted my new tyres and 'forgot' to check which way the front wheel spacer went.
It has a thin shoulder on one side ( That I have next to the fork leg ) and a thicker shoulder on the other side ( That I have inside the wheel )
Is it fitted the correct way ??
I only ask because the front wheel does not seem to spin very easily, it does go round but not as freely as I would have though it should, it could have been like this before but I never tried it before taking the wheel out.
Old 18-Oct-2005, 19:58   #2
HW HW is offline
I've just taken a looksie, and it's going to be tough to tell.
What I can see without taking my front wheel out, is the the wheel side the flange is almost flush with the seal (just a sliver showing) and the fork leg side there is about 4 mm. I would not be able to compare the two sides without taking it out. I think you should look at the wheel side and see whether the flange is proud of the seal or not.
Does that help? Is there anything else I can do?
Old 18-Oct-2005, 20:02   #3
iang's Avatar
HW, cheers you have confirmed that I have it in the correct way, the bit that you cannot see ( wheel side ) is about 20 mm wide which is inside the bearing and the fork side is about 4 mm.
Thanks Again
Old 18-Oct-2005, 20:03   #4
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
Don't know what bike yours is !!!!!
but i would have thought if it was the wrong way round the calipers would not line up!
Old 18-Oct-2005, 20:06   #5
HW HW is offline
Nah, he means the loose spacer which could be reversed, not the wheel. It has a thicker flange on either side, one side thicker than the other.
Old 18-Oct-2005, 21:42   #6
You should be able to see a mark that the seal inside the wheel has made...........
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:15.
