General Motorcycles only
Old 22-Oct-2005, 20:03   #1
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
snapped exhaust stud
Hi Guys,
The exhaust on the 888 is now off (probably for the first time in 12 years) but despite a weeks worth of soaking with penetrating fluid I still managed to snap one of the suds on the horizontal cylinder. I've got about 5mm of the stud sticking up to attack and would appreciate advice re the best way of trying to shift it (please don't suggest trying to drill it out as experience has shown I'm c**p at doing that!). Anything that avoids having to helicoil it would be great. Would welding a nut to what is left be a good idea ie would the heat help loosen it?
Thanks,
Keith
Old 22-Oct-2005, 22:07   #2
Screwy Screwy is offline
Screwy's Avatar
Welding a nut to it sounds good and yes the heat would probably help in loosening the stud . Good luck
Old 22-Oct-2005, 22:32   #3
chris999 chris999 is offline
Mood: red and proud !!!!
nut is good idea...
had lots of success using a spark aroder in simalar situations.
access needs to be good or take head off..
try local engineering firms or get it to me...
top bit kit which will arode straight in and is not affected by metal hardness..
would use a hex head bit - arode in 10 mm and just unscrew broken stud out...
pm me if you need to..
Old 23-Oct-2005, 21:38   #4
keith888's Avatar
Mood: On the up
Thanks guys. I'll give the nut idea a go next week and see if I can avoid having to pull the head.
Keith
Old 24-Oct-2005, 00:21   #5
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
I want my 888 system polished over the winter and im bricking it at the thought of taking it off for this exact reason..good luck !
Nat
Old 24-Oct-2005, 00:22   #6
Davieravie Davieravie is offline
Davieravie's Avatar
Mood: Warmed up and ready to go
mole grips
Old 24-Oct-2005, 10:18   #7
keith888's Avatar
Mood: On the up
In hindsight I should have used a cutting disc on a dremel to part cut through the nuts. I did this on one of the other nasty looking nuts and the nut spun off after a few knocks with the cold chisel without hardly marking the stud. I'm not sure there is room for a nut splitter unless you can get mini versions. I hope the shiny pipes will be worth the hassle...
Keith
Old 24-Oct-2005, 19:24   #8
keith888's Avatar
Mood: On the up
I've just managed to shift the blasted stud. The stud was in VERY tight. I kept failing to get a strong enough weld to a nut. In the end I built up the stud with weld until it was glowing nicely then clamped it with the Mole grips.
Keith
Old 24-Oct-2005, 19:28   #9
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Keith... if it ain't broke , don't fix it.
What you up to with it anyhow?
Andy
Old 24-Oct-2005, 21:31   #10
keith888's Avatar
Mood: On the up
Hi Andy, The 888 is stripped for a full checkover (I always like to do this with a 'new' bike). The exhaust looked so scabby that it seemed a shame not to take it off and give it a polish. Basically, us 'classic' owners spend our Winters getting cold in the garage rather than getting cold riding
Who knows I might even make one of your rideouts next year if I can work out how to put it all back together!
Keith
