Old 22-Oct-2005, 20:15   #1
barryj barryj is offline
748 Chip and Battery info please
Hi
I am a new 748 owner (previously only having owned 2 strokes, RG5's RGV's etc) my bike is fitted with Carbon Termi's but I am wondering how I can find out what chip it is ruunning. The rubber bung has been removed at some point so I am assuming that it has an aftermarket one. Has anyone any information on what the markings mean?
Also does the bike not run well when the battery is stuffed? I was out today, the battery is flat (had to bump it) and not holding charge and the bike started running badly.
BJ
Old 22-Oct-2005, 23:19   #2
The chip could have come from one of several sources. what are the markings?
It sounds like you could have a charging problem. It's not uncommon for the alternator wires to fry themselves.
Take a look behind the battery tray and look for 2 or 3 yellow wires. There'll be a connector/s of some sort where the connect to the regulator loom. Chances are these will have fried.
Cut them back and fit new connectors. Wrap them in tape to keep them clean.
Old 23-Oct-2005, 11:50   #3
supergray supergray is offline
supergray's Avatar
Mood: The Wah rock so hard!!
Hi just backing up what nelly says, i'm a new 748 owner and the wires behind my battery were fried i also had to replace the rectifyer. (pattern part was cheaper!)
Old 23-Oct-2005, 20:55   #4
nothing wrong with the wiring, the battery is stuffed it wont hold a charge for more than a day, a voltmeter accross the bike when running gives the best part of 14 volts, a new battery is on its way.
The main thing I am asking is, that when the battery is flat and the bike is running of the genny through a stuffd battery can it make the bike run crap? I am thinking maybe it could effect the fuel pump/brain etc....... when I was riding the bike yesterday after having to bump start it it was running bad.
BJ
Old 23-Oct-2005, 22:21   #5
the info printed on my chip is:
MS10 printed on a white sticker on the chip
printed on the actual chip:
27c256-10
BLU782A708
Thailand
The bike is running 45mm Termi's and no airfilters (only just discovered and I am about to fit some!)
Any help would be really apprecited
BJ
Old 23-Oct-2005, 23:55   #6
Sounds like it is the battery that is giving you problems.
If the regulator is stuffed, you will usually get weird tacho readings and the temp gauge goes doolally whilst riding.
The MS eproms originate from Italy I believe. Couldn't tell you exactly which one you have though.
if you want peace of mind, order one of JHP's via ducati Coventry. tell them exactly the setup of the bike and they'll burn one to order.
The bike will still probably need/benefit from getting setup correctly though.
If you're going to buy new filter, look at the Pipercross MPX038's. the fit exactly the same as the OE ones, seal a lot better, last longer and flow better. £20 or so a set
Old 24-Oct-2005, 19:23   #7
now, my tacho is giving strange readings zero at tickover and drops and rises at high revs...................now I am confused!
Any idea how I test the REG/RECT, I have some electrical knowledge....................a little knowledge and all that!
Sorry for all the questions guys
[Edited on 24-10-2005 by barryj]
Old 24-Oct-2005, 19:44   #8
PDL PDL is offline
Bikes: 803 rs race bike
PDL's Avatar
Sounds like you need a new battery, I have the same trouble recently, is your bike alarmed?
These are all the chip numbers from a previous post:
96502394C - 916 Monoposto '94, silencers Racing
965013AAA - 916 Biposto silencers Racing
965015AAA - 996 Racing silencers
965014AAA - 748 Twin-seat silencers Racing
965024AAA - 748R Silencers Racing
96502694C - 916 Monoposto '94, silencers Ø 50
965027AAA - 916 Biposto silencers Ø 50
965025AAA - 996 Silencers Ø 50
96506501B - 996S Silencers Racing Ø 50
965028AAA - 748 Biposto silencers Ø 50
965029AAA - 748SPS Silencers Ø 50
965030AAA - 748R Silencers Ø 50
965031AAA - 996 Complete assembly Ø 50
965032AAA - 996SPS/916SPS Complete assembly Ø 50
96503394C - 916 Monoposto '94, complete assembly Ø 50
96503494C - 916 Biposto complete assembly Ø 50
965035AAA - 916SP Complete assembly Ø 50
965036AAA - 748 Biposto complete assembly Ø 50
965044AAA - 748SPS Complete assembly Ø 50
965037AAA - 748R Complete assembly Ø 50
965038AAA - 996 Complete assembly Ø 52
965039AAA - 996SPS/916SPS Complete assembly Ø 52
965040AAA - 916 Biposto complete assembly Ø 52
965035AAA - 916 SP Complete assembly Ø 52
