Old 28-Jul-2013, 23:33   #1
DAVEST205 DAVEST205 is offline
MT940B1 Dash
Managed to get a Marelli MT940B1 dash (CS-600 kit) installed today, upon turning the bike on, wry thing appears to be ok other than no rpm figure is displayed, I've not tried riding the bike yet so not sure if speed will be showing correctly either as its showing '5' at standstill.
Anyone with this dash installed, does the rpm and speed need configuring, does anyone happen to have a copy of their settings for rpm and speed.
The opening screen shows 'Ducati DL2.9) then 'NOTPRO'...
Old 29-Jul-2013, 02:21   #2
Yes Speed will need configuring and I suspect the rev counter will as well as it would differ between a bike with a P8 ECU and one with a 1.6M or a 59M ECU
Old 29-Jul-2013, 09:22   #3
Cheers skidlids, I'm using the front brake disc bolts so presuming I set this to 12 pulses, will have a dig regarding the rpm pulses.
Ta
Old 29-Jul-2013, 11:55   #4
Ta
Yes 12 pulses, i did an article for Pronto about it a while back
Here is the summary
Summary: -
From my findings you don't need a special trigger ring and the trigger points do not have to be evenly matched.
Use Allen bolts as disc fixings and as trigger points, these will generate 12 pulses per rotation.
For a 120/70/17 Pirelli tyre use an input figure of 10344 for MPH speed-readings.
For a 120/70/17 Michelin tyre use a figure of 10427 for MPH speed-readings
I also have PDF copy of the manual if you don't have one, if you need it just send a email request to skidlids@ntlworld.com
Old 29-Jul-2013, 12:26   #5
That excellent mate, will try that later.
You have mail also.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
