Old 23-Oct-2005, 17:45   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
headlight bracket removal
What is the easiest way to remove the headlight bracket and clocks in a oner.
As I stand here scratching my ar......head.
Dave
Old 23-Oct-2005, 18:46   #2
After removeing the top fairing disconnect the switch gear connectors along with the indicator connectors, also disconnect the speedo cable at the wheel end. Remove RH fairing panel and undo the metal mutiway plug.
Drop the rad off its mount so the metal multiway andn pass through
Then remove the two bolts that attach it to the frame.
I think that about covers it
Old 23-Oct-2005, 19:20   #3
dave996's Avatar
Mood: Fed up...
Cheers Kev, can't get the metal multiway plug disconnected
Old 23-Oct-2005, 19:52   #4
Twist and pull
Old 23-Oct-2005, 21:04   #5
dave996's Avatar
Mood: Fed up...
Cheers mate, it's freeeee
Now......how the hell does the plug get past the radiator without removing it
Old 23-Oct-2005, 21:51   #6
keefer keefer is offline
keefer's Avatar
just drop the rad down you dont have to drain it
Old 23-Oct-2005, 21:58   #7
keefer's Avatar
any way what you doing ?
new carbon jobby
Old 23-Oct-2005, 22:24   #8
Originally posted by skidlids
7 fairing panel and undo the metal mutiway plug.
Old 23-Oct-2005, 22:49   #9
dave996's Avatar
Mood: Fed up...
sorry
Old 23-Oct-2005, 22:52   #10
dave996's Avatar
Mood: Fed up...
new carbon jobby
not so glam! I've heard there a bit fragile, is this true.
Starting of with a big clean, then see what new bits I can afford
