Old 25-Oct-2005, 18:44   #1
yeti yeti is offline
yeti's Avatar
One for the computer bods amongst us
Am currently running two monitors off my works computer. At the moment the second monitor is simply an extension of the first. IE, you drag whatever you want across to the second monitor.
I use my #1 monitor (21" trinitron) primarily for 3D CAD, but sometime it would be useful to have #2 monitor mirror exactly what is being displayed on #1. IE when having a technical meeting. I can have the guys sat round the table while I manipulate stuff on #1 and they can see what#s happening on #2. This would save them all crowding round #1.
I can't for the life of me find out if this is possible, and if it is, how to do it. Incidentally, both monitors are running of the same high end graphics card, although #2 connects using a strange square pin plug on the card.
Any idea's?
Old 25-Oct-2005, 18:56   #2
guest1 guest1 is offline
Try the video cards website?
Old 25-Oct-2005, 19:01   #3
Sorry Yeti if it appears to be "teaching granny to blow eggs" etcetera, but should it not be under your control panel>display>primarysecondary monitor settings
Old 25-Oct-2005, 19:04   #4
yeti's Avatar
The only option I have is to set #2 as a "slave" to #1
Old 25-Oct-2005, 19:36   #5
xp pro?
http://www.microsoft.com/resources/d..._overview.mspx
Old 25-Oct-2005, 19:49   #6
phil_h phil_h is offline
phil_h's Avatar
Well, it all depends ...
on what your video adapter driver allows you to do.
Step 1 is to realise you can set your monitor settings seperately ...
in the 'display properties' dialog witht he 'settings' tab selected, you should see a grey box with your monitor shown as '1' and '2' (say)
You may be able to click on each of them and set (a few) properties up seperately.
As a developer, I (ands loads of others) have run 2 and 3 monitor systems quite a bit, but almost always as big extended desktops.
In this situation, you use a setting like 'extend my desktop onto this monitor'
I think what you want is a 'slave' of your first monitor, but neither of the display adapters on my 2 systems here at home have that kind of setting :-))
I'll have a look a work (on yet another system) for you tomorrow
Old 25-Oct-2005, 20:14   #7
yeti's Avatar
Thanks guys, not at work at the mo so can't try it. Will look at it again tomorrow
Old 25-Oct-2005, 21:01   #8
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Click mirror displays on the toolbar, oops sorry forgot only Apple make it that easy
Old 25-Oct-2005, 21:21   #9
yeti's Avatar
'koff
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:36.
