Old 26-Oct-2005, 12:30   #1
MARTIN H MARTIN H is offline
MARTIN H's Avatar
996R tyre choice?
My 996r has Diablo Corsas on at the moment, the front is ok but the rear is worn out. At the moment it has a 190 on the rear and I am thinking of changing to a 180? I have raised the rear of the bike a little to quicken the steering but it still feels slow to turn (compared to my Multistrada) I know I changed to a 180 a few years ago with my 996s and that quickened the steering up a lot.
I had read on here that it was not a good idea to put a 180 on the (wider?) rim wheel fitted to the 996r. I have had my steel rule out and the rim on the 996 seems to be the same width as the rim on the multistrada (which has a 180 rear)
I have searched through the archives and cant seem to find a definitive answer.
Also as I am intending using the bike when I can over the next few months (dry days no salt etc) would I be better of fitting a normal Diablo instead of the Corsa? I have heard the standard Diablo is a better tyre in cooler/damper conditions.
Old 26-Oct-2005, 13:19   #2
BDG BDG is offline
BDG's Avatar
Martin my R has a 5.5 inch rim as standard, and thats the size my manual specifies as well.
I have gone to a 180 as well, much better.
Have run standard Diablo's and corsa's.
Standard diablos are fine for road use (and i think the DD boys use the standard ones for racing as well i believe).
I only put corsa's on for Cadwell and Rocky, as the standard ones were worn out.
N.B. i have 2 full turns extra on the ride height as well.
Yes they should work better in the cold as well.
[Edited on 26-10-2005 by BDG]
Old 26-Oct-2005, 17:49   #3
MARTIN H's Avatar
Cheers Shaun, I have ordered a 180 standard Diablo. Like you I have 2 extra turns on the ride height which improved things a lot but I think the 180 will get it just right as it did on my 996S. I have Diablos on the Multistrada and cannot fault them wet or dry.
Paid £100 all in for the 180 Diablo including vat/fitting/balancing, seems a good price?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:24.
