Old 28-Oct-2005, 12:25   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
choke cable replacement
Am i right in thinking that the handle bars have to be removed to replace the cable.
Old 28-Oct-2005, 12:58   #2
Is it a carb'ed Monster? If it's anything like the 600SS then no you wouldn't have to, but you'd need to remove the tanke and airbox to get at the carbs, which can be a real pain!
Old 28-Oct-2005, 13:13   #3
carb monnie
yeah it's a carb 600 '95.
it is abit bit of a mare with the airbox having to come off done that job before
looked like the cable holder (plunger bit) was held in place by the bars. Will the cable will thread through without having to remove it.
Old 28-Oct-2005, 13:13   #4
stef stef is offline
yes, if it is carbed, you will need to take the tank and box out.
but you could also get away with not replacing it. I removed mine altogether. It's ugly, jams, and the choke can be pressed in manually at the side of the carbs. This way, you dont ride with the choke on (better for the engine)
I have been runing a 600 this way for two years, and removed it from the 900 as soon as i got it.
i recommend it.
Old 28-Oct-2005, 13:38   #5
Don't know the setup of the bars on the monster, but the engine is the same as my 600SS and you'd definitely need the airbox off to replace the other end of the choke cable on the carbs.
Looks like it'll be a weekend job!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:20.
