Old 05-Aug-2013, 05:45   #1
DAVEST205 DAVEST205 is offline
Button/Switch Control for MT940 Dash
Hi,
I need to find a clip-on mounted button/switch to control a Magneti Marelli MT940 dash. It needs to be be able to activate one press to scroll through menus and a longer press to select options.
Can anyone recommend anything suitable?
I see that the translogic microdash has an external button, has anyone got one?
Ta
Old 05-Aug-2013, 09:29   #2
KTM Mode switch
http://www.ebay.co.uk/itm/2011-2012-...item35c61bc1b9
Old 05-Aug-2013, 10:35   #3
I've got one of those KTM mode switches that I wanted to use on my 748 with Translogic dash, but I found that there wasn't enough room on the bar and also that the button would restrict movement on full lock due to hitting the air ducts.
I'm going to try using a basic push-to-make switch mounted via a home-made bracket (I have some left-over carbon from making the dash mount!) and mount it off the clutch reservoir.
Old 05-Aug-2013, 10:41   #4
Just found these, look ideal!
http://www.pashnit.com/product/pmr/thumb_switches.html
Old 05-Aug-2013, 15:11   #5
Or
http://www.ebay.co.uk/itm/Dynojet-Mu...em2c70e 74a2c
Old 06-Aug-2013, 10:46   #6
TransLogic sell their own button for their dash - it's just a momentary (ie, not latching) push button mounted onto a bar clamp. You should be able to use that on yours if you change the connector.
Part number TLS-HBB-1-B, £49.99 + VAT.
http://www.translogicuk.com/spare-parts.php
Old 07-Aug-2013, 15:57   #7
Cheers chaps,
Will go for either the translogic (when their back from holidays) or the pmr one.
Thanks again
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:25.
