Old 30-Oct-2005, 12:03   #1
weeveetwin's Avatar
Garage building. How much will it cost..?
Hi all..
Has anyone ever had a garage (or smaller bike-storage-type-thingy) built onto the side of their house?
If so, what kind of costs were involved? A ball-park figure will do.
I'm thinking about a brick built unit, about 8ft x 10ft - fitted onto a corner of the house, so-to-speak, with two of its walls actually formed by the existing property. It'll have a skylight on its roof, and a bike sized roller-shutter door on the front.
Any ideas? Cheers.
Steve
Old 30-Oct-2005, 12:08   #2
GsxrAge GsxrAge is offline
GsxrAge's Avatar
go big mate mines 32ftx15ft fit the car and 2 bikes in and still have space to play
Old 30-Oct-2005, 13:29   #3
A builder we use at work quoted me £10k plus for a traditional detached single garage. I think you could buy the materials and build it your self for somewhere around £2.5K. Work it out, bricks measure 102.5mm wide by 215mm long by 75mm high plus a 10mm joint. They cost around 20p each.
Concrete for a base is about £65 a cubic metre and the slab will need to be at least 150 thick.
Concrete sectional garage cost about £1500 including delivery and building (plus slab).
Old 30-Oct-2005, 14:03   #4
20p per brick...maybe if you live in a council house.
try double it at least, concrete £70 +vat per m3
sand cement roof timbers ,what about internal walls , roofing tiles , garage doors (around a grand) elctrics lighting
£10k not so bad after all, end of the day would you paint your own duke...get the pros in
Old 30-Oct-2005, 14:05   #5
Originally posted by weeveetwin
Hi all..
Any ideas? Cheers.
Steve
Around 4k inc door etc
Old 30-Oct-2005, 14:22   #6
yeti yeti is offline
yeti's Avatar
I'm just finishing a bike workshop/garage/office. It's 32 x 24 ft and is built entirely from plywood. I built a timber frame first then clad it with 1/2" exterior ply on the outside, lined the gap with various thickneses of polystyrene and clad the inner walls and roof with 1/4 ply. The foor is tongue n grooved floor sheeting. With electrics etc I'm not gonna see much change out of 10k.
Old 30-Oct-2005, 14:38   #7
monstermob 998's Avatar
60 bricks the meter square
10 blocks to meter square
60 clay tiles to meter square
i worked out a cost earlier but was waiting for others the size you want plus proper footings (not a raft) pitched tiled roof cavity walls insulation electrics and skylight labour skips etc you wouldnt get a lot of change from the 6k mark inc vat + of course the cost of yer shutterdoor thingy-- based the price around the southern prices--- id even chuck in some ground anchors for a fellow biker
Old 30-Oct-2005, 15:17   #8
Ahh the great north / south divide, why arnt bikes cheaper oop north
Old 30-Oct-2005, 15:45   #9
rcgbob44's Avatar
8 x 10 is to small , make it bigger so that you can move around a bit!
Old 30-Oct-2005, 16:00   #10
khushy khushy is offline
khushy's Avatar
we are having ours built right now - £3700 + VAT + £1000 for the roller door - all in!!!!
5m x 6m - incl all footings, render, tin roof etc etc
Khushy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:18.
