Old 31-Oct-2005, 18:04   #1
851neil 851neil is offline
Mood: need a bike...
Ohlins Forks
Could any of you guys help out an impoverished 851 rider ??
I'm after a dimension from the top of the fork leg to the centre of the spindle on a set of 996 or 998 Ohlins road & track forks. Just thinking about upgrading the forks.
cheers
Neil
Old 31-Oct-2005, 18:30   #2
Mr_S Mr_S is offline
Impoverished and Ohlins don't normally sit together in the same discussion!!!!
Sorry, don't know the dims.
Old 31-Oct-2005, 19:20   #3
Ladybird Ladybird is offline
Mood: nearly brave enough..
710mm near as makes no odds. Thats with the bike on the ground/stand. Obviously if you need a little more or less, you could drop them through the yokes a little. I have around 15mm protruding above the top yoke.
FWIW, I may be selling mine in the near future. They will prob come complete with Brembo monoblock calipers (Pre radial), discs, lines and AP span and ratio adjustable master cylinder.
U2U if interested.
Old 31-Oct-2005, 19:52   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Neil,
Take a look at the cyclecat wab site and you can buy a nice 888 yoke conversion to take the 53mm Ohlins. Fiscus has a set on his SS with Showas.
Rgds, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:44.
