Old 02-Nov-2005, 12:16   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Alloy cutting
Hi DD people,
I'm trying to build my own brackets to fit standard SSie rearsets to the Monster. So I've bought that:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=7558489994
Now my problem is I don't really now how to cut it like I'd like to
I've tried with that tool
But I can't cut it in a straight line. I've also that thing in my garage
but I'm not sure the result will be nice...
Any idea? How would you do it?
Old 02-Nov-2005, 12:21   #2
Dave G Dave G is offline
Dave G's Avatar
Draw your pattern on the metal and take it to the nearest metal fabricators and get them to do it for you,explaining whats important,should cost pennies.
Old 02-Nov-2005, 12:23   #3
Scotty Monster Scotty Monster is offline
Scotty Monster's Avatar
Mood: counting
use the hacksaw draw a line to follow
take you time and dont loose ya rag , try and do it all in one session and practice makes perfect then break the file out to trim the rought bits
then decide its not good enough and spend even more cash on the real thing
Old 02-Nov-2005, 13:02   #4
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Jig saw is best use a course blade.
Old 02-Nov-2005, 14:11   #5
Andy C Andy C is offline
Hi guys, i,m currently building a DD bike for next year and am going the same way. The firm that i got the ally sheet from told me to squirt some parrafin on the jig-saw blade while cutting it, stops the blade wearing down. Have'nt tried it yet but he's sure it'll work.
Old 02-Nov-2005, 14:16   #6
desmojen desmojen is offline
Mood: DOH!
Don't use a grinder Tonio, you can't see the sparks with aluminium and you will damage the heat treatment with the heat it produces.
If you don't take Dave G's very good advice then do the following,
Using a scriber, carefully mark out where you want to cut to.
Now use a hacksaw with a fresh blade to cut just outside the line, really close though. Use plenty of lubricant whilst doing this (WD40 or paraffin).
Once it's cut out, clean the lube off and mount it in a vice with some card packing or similar to prevent damage to the surface of the part, and then carefully file down to your scribe lines.
Use progressively finer files and finish off with wet'n'dry sandpaper to remove scratches from your cut lines.
Put a very slight chamfer on your edges and jobs done.
This will take absolutely ages but if you are careful you can create some very nice work
Old 02-Nov-2005, 17:38   #7
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Ideal tool would be a jig saw with the proper Aluminium blade in it.Go through like a knife in butter. Be careful and protect your eyes . 4D
Old 02-Nov-2005, 19:36   #8
Get the marked out items to me Tonio and i'll do them on the bandsaw at work, same as I did mine.
If you use a 916 style rear brake mount off the engine cases adapting rearsets becomes easier.
As allloy is a soft material compared to some do not use a grinder. Its best to use a coarse cutting blade and a proper cutting fluid. As Fordie says a Jigsaw with the right blade will do the job.
Also use a coarse file when dressing the edges.
Old 02-Nov-2005, 20:11   #9
Davieravie Davieravie is offline
Davieravie's Avatar
Mood: Warmed up and ready to go
And get a good quality paint.........it covers up all the mistakes...the thicker the better!!!!!! I should know
Old 02-Nov-2005, 21:52   #10
Mood: Avatar what Avatar
Tonio 600
u2u me with what you want made as long as its not to big I may be able to help.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:40.
