Old 03-Nov-2005, 22:17   #1
TV Problem
A mate of mine wants to give me his 32 inch 100 hz thompson widescreen tv. He's just moved house and the tv doesnt work very well in the new house! So i said rather then chuck it out he should give it to me. Now he's telling me that sometimes it won't turn on. The sound comes on but you have to work the switch two or three times to get the picture to start up.
I seem to remember reading that a fault like that is serious, power supply or something. Anyone got any ideas?
Old 03-Nov-2005, 22:21   #2
rcgbob44's Avatar
Could be a problem with the switched mode power supply not firing up properly!
Anyway as its a Thompson you might as well just bin it!
Old 03-Nov-2005, 22:26   #3
Thats what i though! Most people think its the switch but i was sure i'd heard that switch mode psu problems give that fault. Think i'll tell him to forget it and save me the bother of finding a skip for a huge thing like that!
Many thanks.
Old 04-Nov-2005, 11:02   #4
HW HW is offline
I've had power supply fixed on a Toshiba widescreen, didn't cost too much (if you call £50 not too much) .
Old 04-Nov-2005, 12:10   #5
Main problem is that i've got one chance of getting this thing home. I've got to borrow the works car then i'm stuck with it at home! If its not something i can sort myself then i'll leave it alone i think!
Old 04-Nov-2005, 13:08   #6
berto berto is offline
Once the tv is on only switch it off by using the standby button......
Old 04-Nov-2005, 13:56   #7
Good plan but that doesnt work either as the psu wont fire up to get the tube going!
General opinion is that thompson are crap anyhow!
Old 04-Nov-2005, 14:12   #8
LesPaul LesPaul is offline
LesPaul's Avatar
Mood: Not sure
Can't really argue with that
Generally the electrolytic caps in switch mode power supplys need changing, the heat generated by this type of power supply doesn't do them alot of good.
Used to get kits of caps from companies like SEME in Melton Mowbray for various manufacturers power supplies, used to be a real pain in Sky receivers.
Darren
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:15.
