Old 16-Aug-2013, 13:49   #1
milli milli is offline
milli's Avatar
ST2 starting problem
hi all my st2 has a starting problem. starts fine most of the time. when I stop put fuel in go in pay. then back to back turn key nothing no noise at all everything lights up. after about 5 mins wait she goes. did think the side stand switch but not sure now. does only seem to be when the engine is hot. hope you lot can help milli.
Old 16-Aug-2013, 14:41   #2
dunlop0_1's Avatar
Sounds like a basic wiring/connector fault contact/no contact etc. You can link out the side stand switch with a short piece of wire to eliminate it.
Old 16-Aug-2013, 17:28   #3
milli's Avatar
strange thing is it only happens when the bike is hot. never had a problem any other time. suppose I should eliminate the side stand switch.
Old 16-Aug-2013, 20:07   #4
Not sure how to read your post
Is it like this
followed by
Or do we read it like this
followed by
Old 17-Aug-2013, 07:10   #5
milli's Avatar
switch on with key, lights come on. press starter and nothing even happens on centre stand .
Old 17-Aug-2013, 07:19   #6
dunlop0_1's Avatar
You need to check the two wires/connector that goes to the starter solenoid. When you press the starter button this energises the solenoid thus the starter. If the bike will bump start when the problem happens then you may have found your problem.
Old 17-Aug-2013, 16:21   #7
If lights come on that should rule out the ignition switch and the ignition relay
Does the fuel pump prime, if so main suspects are right hand switch gear (start button), start Solenoid or the starter motor itself, the brushes in these do wear down, also the commutator wears and if the oil seal goes the commutator ends up frying in oil
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:10.
