Old 05-Nov-2005, 22:54   #1
enigma enigma is offline
Heli bars on 998
Has anyone fitted Heli bars to a 998?, were there any fitting issues?
On the stock bars how easy is it too rotate the levers downwards a little, so the reach to the levers is more natural?
Heard there is a pin you need too remove, any concerns with doing this?
Bare with me guys the questions will get less..................
.........eventually
Thanks E
Old 05-Nov-2005, 23:06   #2
glj100 glj100 is offline
Hi I have fitted Heli Bars to my 998 (02)
No problems firtting them, leave all cables and brakepipe routings all as original.
I did not have to remove any pins, the only thiny due to the extra cable length is that the trottle is nearly 180deg the other way around due to the cable length.
I got mine from the states as they are a lot cheaper there. saved £50
ljGj
Old 06-Nov-2005, 12:21   #3
MARTIN H MARTIN H is offline
MARTIN H's Avatar
From memory the Helibars dont have the pin that locates the levers in a set position. Which is better as you can locate the levers to suit you.
Old 07-Nov-2005, 00:17   #4
BDG BDG is offline
BDG's Avatar
Heli bars are superb, as for fitting, an absolute doddle, Nelly fitted them when he serviced the bike
Old 07-Nov-2005, 09:34   #5
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
The standard bars have a little locating pin to position the controls. From memory, it can be twisted out with a set of vise grips. If not, it's easy to grind off, and then you can swivel the levers around to a position more suited to humans.
Spinoli
Old 09-Nov-2005, 21:21   #6
m1keyp m1keyp is offline
It depends on what you are trying to get from the bars.
I needed them higher and ended up with the cyclecat ones www.cyclecat.com
Transformed the bike for me
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:34.
