Old 08-Nov-2005, 11:42   #1
loverobot's Avatar
Tools..............
I recently purchased a 748s 2001my
I need to stop up on the boggo tools I need so please advise -
1.does anyone know the nut sizes for removal of the rear wheel - I intend to buy 1/2" drive sockets
2.is there a specific tool / size for adjusting the eccentric hub?
3.what size torx? screwdriver / socket is needed to remove the screen?
Has anyone found / caused any electrical / alarm problems by wiring a =ve and -ve wire onto the top terminals so as to allow a plug in of a battery conditioner?
Its currently on standard dragon evo (corses?) - what road tyre pressure is everyone using?
Thanks in advance
Nick
Old 08-Nov-2005, 11:55   #2
Harv748 Harv748 is offline
Harv748's Avatar
1: 46mm wheel nut side/ 41 mm sprocket side/ 28mm front wheel
2: The tool for the hub should be in the tool kit...looks lke a large C spanner with a box section piece for the handle.
3: Torx 7 I think?
4: No problem with connecting up a charger to the battery...have optimate terminals on mine.
5: Tyre pressures are a personal thing...but 36 psi front and rear will put you close. Theres a great post by shazzam somewhere on here about tyre pressures and working them out to suit your riding style. Try a search on it.
HtH
Old 08-Nov-2005, 11:59   #3
loverobot's Avatar
Thanks Harv
Thought that big nut looked big! If it is torx bits on the front i will just get a little set or something
Old 08-Nov-2005, 12:00   #4
loverobot's Avatar
Sorry just one other thing - there is a tie wrap on the wheel nut but no mention in the haynes manual - is this needed?
Old 08-Nov-2005, 12:08   #5
Harv748's Avatar
Peace of mind really...you don't need one but you'll be suprised at the number of bikes that have them on!
Old 08-Nov-2005, 12:09   #6
You'll also be surprised at the number of Torx tool kits that don't contain a T7 tool!
You'll need to hunt for it specifically, I lucked out and found one at the BMF show this year. It was the last one too ...
Old 08-Nov-2005, 12:18   #7
loverobot's Avatar
cheers both of you - probably saved me a few quid on a (useless!) torx bit set!
Old 08-Nov-2005, 12:19   #8
loverobot's Avatar
Is this in effect to hold on the circlip then ?
Old 08-Nov-2005, 12:24   #9
yeti yeti is offline
yeti's Avatar
Halfords do a spanking little socket set in their Professional range that has all the tork bits as well. I think it was around 25 squid and comes in a little box etc. Always goes with me on track days.
As for the tie wrap, lockwire will do the same. Good idea, but not strictly neccesary - that said I never go out without!!!
If you don't know how to "do" lockwire, drop me a line and I'll give you the benefit of years of RAF experience
Old 08-Nov-2005, 12:25   #10
keith_mann1959 keith_mann1959 is offline
Bikes: ST4S
keith_mann1959's Avatar
Mood: Finally gotten over the 748R getting stolen thing. Actually, no i haven't !
T6 i'm sure
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:42.
