Old 10-Nov-2005, 08:56   #1
webbyc webbyc is offline
webbyc's Avatar
S/S Nuts & Bolts
Where's the best place to get replacement s/s nuts & bolts from? Especially rear sprocket nuts, rear wheel nut, front calipers joining to forks, heel guards.
Old 10-Nov-2005, 15:05   #2
RickyX RickyX is offline
RickyX's Avatar
Chris,
There's an engineering company in Crawley that does s/s nuts n' bolts. Whenever I need any I make a list of diameter/length etc then add a few extras for luck to maintain stock levels in my "box of useful bits".
They are very reasonable and quite "flexible" on price ("Yeah, a tenner will do for that lot").
Can't remember the name but can supply if required.
R X
Old 10-Nov-2005, 17:56   #3
Jasper Jasper is offline
Jasper's Avatar
Don't replace your caliper mounting bolts with S/S.It's not strong enough!!Look at the thread about my caliper bolts that hold the calipers together!!After much debate,we've decide that it is strong enough for that use!
Old 10-Nov-2005, 19:07   #4
Felix Felix is offline
Jasp, are you contradicting yourself? Is it or isn't it?
Old 10-Nov-2005, 19:11   #5
Gaz 748's Avatar
I use pro bolt, check out there web site at tastynuts.com
Old 10-Nov-2005, 19:31   #6
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Jasp,
I think the M10 x two that hold your calipers on are probably (I can't be arsed to do all the math) well over speced for use.
Yes, SS is weaker, and not the designers choice, but I don't think you'll end up down the road.
You should see the size of the fixings that held most of my racing car together. I think there where only 6 off, M8 bolts on the whole car, and 4 of those where holding the engine!
Rgds, Rob
Old 10-Nov-2005, 20:20   #7
Jasper's Avatar
it IS for holding them together,it ISN'T for mountings.
Old 10-Nov-2005, 20:23   #8
doogalman's Avatar
Chris , get yourself to kempton auto jumble this saturday. Several stainless suppliers there, the best being "Superior Stainless" .
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:58.
