Old 10-Nov-2005, 19:23   #1
Guy C Guy C is offline
Mood: I ordered a Cheese Burger
Noise at rear wheel
Recently started getting a 'clunk' or 'crack' noise at the rear wheel on pulling away, just about the time I've finished with the clutch.
Any ideas?
Old 10-Nov-2005, 19:26   #2
Mr C Mr C is offline
Im no expert as plenty will tell you.
Cush Drive Bushes or Wheel bearing
Old 10-Nov-2005, 19:32   #3
Any way to check without pulling the whole lot to bits!?
Old 10-Nov-2005, 19:43   #4
Wheel bearings aren't that common a fault.
Cush drives - see if you can rotate the rear sprocket for and aft. There should be none, or very ittle play.
The other possibility could be the rear wheel is loose?? Remove the safety clip and check the rear nut is tight.
If you don't have any luck, I'm only up the road in Kirkby. You're welcome to nip over and I'll check it for you.
Old 11-Nov-2005, 09:31   #5
m1keyp m1keyp is offline
If you recently removed the rear wheel check that you refitted the wheel onto the guide pins
Old 11-Nov-2005, 13:18   #6
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Also check the chain
Old 17-Nov-2005, 00:16   #7
Gang , thanks for the help.
Checked everything and got a bit of help in and some play in the clutch is the suspect...soon as I get time wil test
Thanks again.
Nelly, may well drop over to see you
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:03.
