Old 10-Nov-2005, 20:59   #1
pedro pedro is offline
pedro's Avatar
Mood: r
crash bungs 749-999
thinking of the above (just in case) any one got them for the 749-999? are r&g the only options?
Old 10-Nov-2005, 21:40   #2
HW HW is offline
I've got R&G bungs for the 749. I only use them on the trackday fairing, and fortunate I do because I had a low-side off at Snetterton and they saved the bike. Minimal damage, most expensive replacement was a new bung at £26! The whole kit for 749/999 costs £180ish which seems dear but it's a couple of lumps of aluminium which bolt to the sides of the engine mount/frame and then the bungs that go into those. Pretty substantial, and the forces are disipaited through several areas which seems to avoid any frame damage.
Old 10-Nov-2005, 22:11   #3
Bionicle Bionicle is offline
Bionicle's Avatar
Got to agree with henry.... and a low side into the sand trap would have worked out more expencive had i not had them fitted to mine.
Old 10-Nov-2005, 23:17   #4
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
mine come from B&G in Germany
http://www.b-g-racing.de/
€125 yep thats euros!!!
Old 10-Nov-2005, 23:22   #5
HW HW is offline
This was the result of the low side. Half the crash bung ground away, ball end broken off the lever, stainless steel bar end scuffed a little (still using it), billet clutch cover chamfered a bit (still using it, painted the damage black), underside of flip up footpeg ground away (sitll using it, good talking point!), seat unit slight damage.
Old 10-Nov-2005, 23:38   #6
Loz Loz is offline
Loz's Avatar
Hmmm, have to think about bungs for my track fairings now ... seeing as how I don't seem to be immune to coming off.
Old 10-Nov-2005, 23:46   #7
Carbon749's Avatar
Mood: I own a flame thrower
After much soul searching I ended up going the full hog with R&G crash bungs.
I've got the frame set like HW and also fitted the front and rear spindle bungs as well.
I used to work as a turner in an engineering shop specialising in bikes (Metmachex), not an expert but do know a little about engineering.
The R&G kit is very well made and as good as it gets.
The frame kit is very well designed and uses the engine mount and a clamp around the frame with plenty of metal to give support.
I'm sure a big "off" will still wreck the bike, but, I do feel that a moderate low side or the bike falling over would be OK.
I like that I can take the frame bung off, but, leave all the bracket work in place. Therefore, holes in the track fairing for the bung and no hole in the road fairing.
[Edited on 10-11-2005 by Carbon749]
Old 10-Nov-2005, 23:47   #8
HW HW is offline
I am sure that my off could have been totally different and been much more serious. If I'd highsided it then I feel sure they would not have helped. As it was I went down on some coolant on a corner so it just slid out from under me. As I said, the most expensive bit was the new bung and bolt! Very lucky I'd say.
Old 10-Nov-2005, 23:57   #9
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I'd put a bit of carpet on the sides if I was you Pete
It would be a very very slow speed lowside:P
Old 11-Nov-2005, 08:49   #10
pedro's Avatar
Mood: r
underlay would be better jon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:12.
