Old 11-Nov-2005, 15:13   #1
nathanhu nathanhu is offline
nathanhu's Avatar
Mood: head down
999r exhausts !!
due to a bit of a thead hijack i thought id but this up myself..
thanks for the good points JPM and andyb
has anyone else modded an old sytem to fit the new swingarm ??
andyb im on a standard 04 bike with just the open system and ecu fitted with a set of air filters and i got a max of 134ps at the rear wheel........... not as much is i had hoped i can tell you.
and it suffers a realy bad 4-5000rpm flatspot/misfire!!
Old 11-Nov-2005, 15:16   #2
nathanhu's Avatar
Mood: head down
the next thing must be a pcIII and dyno time
which ecu are you using ?
and could i use the standard one with the pcIII with the same effect(my ecu for the 57mm system is for a 999s and is keylocked)
Old 11-Nov-2005, 15:18   #3
I'm getting around 142(ish) I think from mine with a PCIII and assymetric system, think Andy's getting 148 (from memory) with his 57mm system and PCIII
Old 11-Nov-2005, 15:19   #4
nathanhu's Avatar
Mood: head down
hmm the fairing is not a drama as its only on the track at the mo i just need to get it running right as the missfire/power hole ist killing my mid corner confidence and part throttle fueling... it feels like both cylinders are tying to fire at the same time !!!
Old 11-Nov-2005, 15:21   #5
nathanhu's Avatar
Mood: head down
JPM are you using the race ecu or the road one ?
and did yours run as pants as mine
Old 11-Nov-2005, 15:27   #6
Mine was pants because of coil problems, nothing more, I'm on the race ECU that came with the pipes, but the PCIII will override that I am guessing
Old 11-Nov-2005, 15:36   #7
nathanhu's Avatar
Mood: head down
yep i know those problems ... i had mine changed from new as part off the deal
has anyone got there hands on the new style 57mm system yet?
it would be interesting to see which pipes have been modified or is the complete pipework different?
Old 11-Nov-2005, 16:40   #8
As allways, JHP have done the mod.............
PC111 can run with any cpu and be set up..........and much better than any std or "race" cpu!
I have to say, mine pulls like a train, no hiccups or owt! Thats why i am confindent in an out and out drag race, particularly out from a real slow corner, (for what its worth) against all the so called big jap bikes!
Old 11-Nov-2005, 17:27   #9
nathanhu's Avatar
Mood: head down
andy, is your bike a 03 or a 04?
and is your system the one for your bike ie an early exhaust on a later bike?
Old 14-Nov-2005, 04:28   #10
chillo chillo is offline
chillo's Avatar
i get this too around 5k! it really is pants, end up having to try and ride it like an inline four on track losing a lot of the twins advantages!
Had my ECU 'checked' and its supposed to be ok.
got PCIII to go on over winter
