Old 14-Nov-2005, 19:44   #1
BIG-G BIG-G is offline
BIG-G's Avatar
Mood: I started life with nothing and still have most of it left
749 fuel consumption
Now had 6 weeks and getting 85 to reserve and 7ish to litre.
This at normal touring speeds ie 75/80ish but never get out of 4th/5th max.
Is this about right?
G
Old 14-Nov-2005, 20:10   #2
HW HW is offline
Seems a bit high to me. Over past 2 years I have got 115miles to reserve regularly. I don't go easy on it either in case you think that I might dawdle, and that is a mixture of country twisty and in town (a little).
I got 85 on a trackday at Cadwell though.
Old 14-Nov-2005, 20:41   #3
itexuk itexuk is offline
itexuk's Avatar
Mood: Great
Also get around 115 before light comes on,mainly A and B roads. Think you need to use the gearbox more, I use all 6 of them
Old 15-Nov-2005, 08:59   #4
marko marko is offline
marko's Avatar
Mood: happy
I never get more than 100 miles before the reservelight comes on
Old 15-Nov-2005, 09:20   #5
mark749s mark749s is offline
mark749s's Avatar
100 is my limit as well
Old 15-Nov-2005, 09:30   #6
itexuk's Avatar
Mood: Great
When you fill the tank after the light comes on how much can you get in?
Mine is anything from £8.50 to £10 and odd times £11, quite hard to get it actualy full
Old 15-Nov-2005, 10:22   #7
HW HW is offline
£10-50 ish from the light being on. I rarely do any kind of distance riding. I've also altered the gearing a little this year (2 teeth up on rear sprocket) and that has had the affect of riding at a higher revs (by about 500 rpm or so). The consumption may have dropped a little when I did that but not by much really (not below 100). Mostly done track days since then so not sure - above was all based on standard gearing.
Old 15-Nov-2005, 14:59   #8
trigger trigger is offline
trigger's Avatar
My 749s is in standard gearing with a 57mm termi system, light comes on at ~85, never taken it past 100 before a refill. usually fit in about 14 ltrs at the 100 mile mark
Old 15-Nov-2005, 15:09   #9
tricky tricky is offline
Mood: Need spares
I can usually get over 100 before the light comes on, once pushed it to 130 on a tank.
tricky.
Old 15-Nov-2005, 16:08   #10
BIG-G's Avatar
Exact same as me. 14 litres at 100 mile
G
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
