Old 15-Nov-2005, 14:22   #1
tsmales tsmales is offline
Xmas box for my ST2
Hi one and all,
I've been reading the forum fo the last 6 months and have picked up some great advice. I bought a 98 ST2 in June and think it's brilliant. I have decided to give it a bit of TLC over the wet winter months, and was wondering what mods I should consider to prolong my already numerous cold hours in the garage away from the inlaws over christmas !!.
I allready have the starter wiring upgrade to fit, new fairing bolts, new welnus etc.
Is the 14 tooth sprocket a good idea and what about any suggestions to make the clutch a little more user friendly ?
Lok forward to your replies and many more dark hours in the garage !!
Old 15-Nov-2005, 14:29   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
14 tooth sprocket is a must!
Remove the two rubber inlet trumpets from the airbox ( very restrictive ).
Uprated slave cylinder is the way to go for the clutch.
Old 15-Nov-2005, 15:50   #3
HW HW is offline
Get some "red rubber grease" for the welnuts, don't use copper grease (it destroys them).
Uprated clutch slave cylinder is a good idea - Nelly does them, I had one from Tecmoto on mine. That was a slave for a 916, so I am guessing that the ones Nelly has will fit the ST as well.
Cornerspeed
Might want to think about modifiying the bit of side fairing that gets trapped under the nosecone - it's well over engineered and it means you have to take the nosecone off to get the side off (if I remember rightly).
If you find you need any parts I still have a load in the shed ... not got round to getting them on ebay yet.
Old 15-Nov-2005, 17:02   #4
YMFB YMFB is offline
YMFB's Avatar
does that go for the ST4 as well ?
Old 15-Nov-2005, 17:11   #5
Yes
Old 15-Nov-2005, 17:32   #6
Spares ?
Cornerspeed
Thanks for the tips, I don't suppose a left hand mirror or a right hand rear indicator (pannier rack type) would be hiding in your shed ? before I start trauling the breakers and Ebay >
Old 15-Nov-2005, 18:03   #7
Rushjob's Avatar
Mood: :-)
The indicator is the same as the standard one except for the length of wire attached to it.
If you disassemble the old one & remove the wiring you can simply install that into a standard rear one and voila! New pannier indicator.
As for mirrors.. try HW?
Old 15-Nov-2005, 18:20   #8
Depends what's wrong with the mirror. If it's completely missing or broken I can't help you, but if it's just the coloured bit that's scraped or scratched I have a new coloured insert for a LH Mirror. It cost me a fiver, yours for the same cost if you need it.
Oh....it's red...naturally
Old 15-Nov-2005, 19:11   #9
HW HW is offline
Cornerspeed
I think I might have an indicator if you need one. Not certain. I rewired the standard indicator to fit on the pannier rack, then jsut taped up the extra wire when using without the racks. I only fitted the panniers when I went touring.
Sorry, no mirrors - sold them a little while ago. I repaired a hole in one of my original mirrors and repainted it. Couldn't tell it had been done. What is actually wrong with yours?
Old 15-Nov-2005, 19:36   #10
YMFB's Avatar
Dont know if these are an exact match but they look similar and are cheap
http://www.vehicle-wiring-products.c.../mcycle-1.html
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:11.
