Old 16-Nov-2005, 17:03   #1
Anyone tried this ???
Quote from Doug Lofgren's website...
"One of the draw-backs of the 851/888 series has been the air-box. They respond very well to opening the air-box, but, the 888 fuel tank still causes a lot of restriction. Lifting the front of the fuel tank on an 888 can gain 3-4 HP on the dyno, even with an open air-box"
If so it seems like the cheapest of cheap performance mods...and I'm very cheap.
How would you do it? Chock it up on rubber blocks at the front? Modify the hold down clip in some way?
Or not bother?
Old 16-Nov-2005, 17:07   #2
Seen that on a couple of bikes. Not sure of the best way to do it though. Are there rubber blocks down the side that sit on the frame rails?? If so, you might be able to get a spacer under these and then adjust the hold down catch to suit?
Old 16-Nov-2005, 18:25   #3
Yep,the 888 race bikes had their tanks raised at the front.Had a pic somewhere,but danged if I can find it.
Old 16-Nov-2005, 20:48   #4
andya andya is offline
andya's Avatar
Like This?
Old 16-Nov-2005, 21:23   #5
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
From my bike, when open ...
Old 16-Nov-2005, 21:26   #6
phil911's Avatar
... and close !!!
Old 16-Nov-2005, 23:01   #7
Jasper Jasper is offline
Jasper's Avatar
how tall are the rubber blocks?
Old 17-Nov-2005, 00:00   #8
sparkin sparkin is offline
sparkin's Avatar
I thought that was more relevent on the earlier bikes?
Old 17-Nov-2005, 00:04   #9
Ains. Ains. is offline
Ains.'s Avatar
Mood: He's not happy {:o( He's back at sea!
About an inch. See pic. It's Matt Llewellyn at Mallory on an 888 Corsa in 1994.
Ains.
Old 17-Nov-2005, 12:13   #10
851neil 851neil is offline
Mood: need a bike...
I thought that the 888 Corsa ran a sealed airbox ? carbon airtubes feeding into a carbon airbox with adhesive rubber strips (approx 25mm thick) attached to the frame/tank to attain a seal all around - the air box top is in effect the bottom of the tank.
cheers
Neil
