Old 17-Nov-2005, 15:47   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
Air filter: DP or KN?
What's the difference between a KN Air filter and a DP high flow one? On Ebay the difference is about £20 (the KN is more expensive), so is the most expensive the best one or they're the same?
Old 17-Nov-2005, 15:52   #2
Pipercross
Old 17-Nov-2005, 16:01   #3
Tonio - this is one of the few occassions where you will see me write 'dont buy off Ebay'....
I've seen K+N filters cheaper from places like pdq:
http://www.pdq1.co.uk/
and TTS
http://www.tts-performance.com/
(who do pipercross as well) - and usually their post and packing is cheaper as well.
I've always stick with K&N as I bought a kit containing the filter cleaner and re-oiler that still has not ran out after three years!
K&N oil filters are niceas well - built in nut on the end !!!
Frank
Old 17-Nov-2005, 16:18   #4
Tonio600's Avatar
Cheers Iconic...
To both of you, what does pipercross mean?
Old 17-Nov-2005, 16:24   #5
phil_h phil_h is offline
phil_h's Avatar
You get the cut-down airbox included with the dp one dont you ?
(pipercross make air filters mon ami du jambes des grenouilles)
Old 17-Nov-2005, 16:27   #6
Pipercross is another filter, like a K&N.
I prefer the Pipercross as it uses a dual-layer of differing densities of foam, to give better filtration of particles. Like the K&N is can be "washed" and re-oiled (you get a can of oil) so it will last a lot longer than the OEM paper filter.
f you want to practise your English, try reading Shazaam's article:
http://ducatisportingclub.com/xmb/vi...=1701#pid12578
I doubt there is much between the K&N, Pipercross and the DP one to be honest, but you can get a Pipercross filter for around £40 - I think it's cheaper than the K&N ?
I still use the K&N oil filter cartridges. As Frank says, these come with a pre-drilled nut on the end making lock-wiring them really easy.
Old 17-Nov-2005, 16:32   #7
Tonio600's Avatar
Cheers Antonye.
Will have a look at the pipercross ones.
On Ebay KNs are at about £40 and DP £25 I think...
Old 18-Nov-2005, 00:06   #8
D'ailleurs, je pratique mon français - à mon nouveau lieu de travail les trois types sont français, ainsi je dois vraiment pratiquer !
Old 18-Nov-2005, 00:20   #9
Non merde !!!!
Old 18-Nov-2005, 10:52   #10
Tonio600's Avatar
Message original : antonye
Nice one, no mistake
I'd be happy making all my English sentences like that (not in French, but without any mistake).
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:21.
