Old 18-Nov-2005, 19:36   #1
Mood: Avatar what Avatar
M.O.T Failed???
Took my 996 in for a M.O.T today and it failed on the head light diping the wrong way. I had the test done by the Woking M.O.T centre I must say they were very thorough even ran my bike on a rolling road to check the brakes and everything. Anyway it failed so how come Snell's past it for the last two years with the same head light in??
The head light is the original one, I also have one that I bought form the Spares Shack, UK spec they said cost me well over £200.0 and that has the dip going the same way The guy at the test centre said take it apart and bend the deflector around the other way and that should work Any one done this or had this problem
I have stripped one down but can't see how bending it around the other way will help looks like I will have to re make one at work not too much of a problem but so inconvenient.
Old 18-Nov-2005, 19:39   #2
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Hi mate
I had this problem with my parallel import 916. Baines Rcaing do a little kit for a few quid to convert it...job done !!
Nat
Old 18-Nov-2005, 19:39   #3
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Had the same problem with my 851.....
Piece of red insulating tape on the appropriate part of the glass fixed it.
It then passed.
Old 18-Nov-2005, 19:44   #4
I suggested the tape route philthy he he wasn't having any of that
Old 18-Nov-2005, 20:22   #5
Steve B Steve B is offline
Mood: counting down to mad sunday
I did the same as Nat suggests.
Geoff Baines sold me a replacement deflector plate for my imported 916 back in 1997 for less than a tenner. It's a simple job. Once you have got the headlamp unit out it is just two small screws to get the USA/European plate off and replace it with a UK/Japan/Aussie one.
Steve
Old 18-Nov-2005, 20:34   #6
Rick Rick is offline
If you do screw out the plate DONT throw it away I am thinking of buying another Ducce from the UK and bringing back to Sweden so I might buy it from you , IF i find a bike
Old 18-Nov-2005, 20:35   #7
philthy's Avatar
Just go to ****** in *******
He'll pass it for you
Old 18-Nov-2005, 20:41   #8
I replaced my deflector with one I made from a alloy coke can, easy peasy
Old 18-Nov-2005, 20:58   #9
Paul748bp Paul748bp is offline
Paul748bp's Avatar
i find that alot of dealers have different views on passing MOT's mine failed on my front wheel rims because they had a tiny kink in them from the dreadded pot holes but i was told from the local tyre fitters that they would have passed it ?????????????????
Old 18-Nov-2005, 21:38   #10
Stu748R Stu748R is offline
Mood: I've just ordered a new bike and its a ..
Sorry to hear your news,the're being a bit a*al me thinks but Snells are straight down the line on all M O T'S so take it there and don't ask the questions.
Hope your well roadrunner.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:24.
