Old 19-Nov-2005, 21:52   #1
duc daz duc daz is offline
duc daz's Avatar
open clutch virgin
had a JHP clutch cover pressure plate and caps and springs fitted and im so impresed it looks so much better than the standard...thanks again pedro 749R
Old 19-Nov-2005, 23:33   #2
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
You soon have an empty wallet Daz or a big cc bill.
Old 19-Nov-2005, 23:35   #3
mucka749 mucka749 is offline
Mood: chilled
you got any pics
Old 21-Nov-2005, 00:09   #4
749er 749er is offline
749er's Avatar
was in the middle of fitting mine yesterday, when I found that some kind soul at the garage where it was serviced had managed to destroy the head on one of the 6 bolts which hold the pressure plate, so it wont come out.
Planning to use a dremel to cut the springs and the collar, slip the spring and collar out. Then use a pair of vice grips to get the bolt out. If anyone has a better plan, please let me know. Want to get my bling on pronto.
Old 21-Nov-2005, 00:19   #5
Drill the head of the bolt out with a 5mm drill. Once the cap is off and the spring tension relieved, you'll more than likely undo the bolt thread with your fingers.
Old 21-Nov-2005, 00:27   #6
749er's Avatar
did think about that, am a bit concerned about wrecking the thread though
Old 21-Nov-2005, 00:51   #7
I've done it several times with no damage at all. You'll make a bigger mess with the dremel IMO. The threaded portion of the bolt will remain 2 or 3mm proud of the spring post. As the head of the bolt gets drilled out, the spring pressure will finish the job off for you.
Take your time and it'll be fine. You'll save the cap and spring to.
Old 21-Nov-2005, 09:48   #8
yeti yeti is offline
yeti's Avatar
I'll ditto all that, Nelly did it on my bike and I was astonished when he finished the job of with his fingers.........
Old 21-Nov-2005, 18:35   #9
749er's Avatar
Hi
So if I understand correctly, the drill takes enough of the head off to allow the plate and spring to slide pas and be removed easily, leaving about 3mm off the bolt to be loosed by say a set of vice grips.
Am interested in the rear sprockets you have for the 749, 525 chain, not sure which version though. If you can let me know which one I will get the cash over to you.
Thanks for your help.
Derek
