Old 20-Nov-2005, 13:21   #1
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Shock Removal - help !
Still having a shocker (groan) getting the std showa unit out.
Now got the top bolt undone, and the bikes balanced niclely on some axle stands, but the bottom one doesnt want to know...is that some sort of collar on the other end..am I right in assuming its juts an 8mm bolt that needs undoing ?
At the moment im just trying an allen key with an extenion tube and lashings of WD40. I suppose next step is plusgas and an 8mm allen socket ?
Any advice appreciated !!
Nat
Old 20-Nov-2005, 13:27   #2
keefer keefer is offline
keefer's Avatar
give the WD some time to work.
the bolt goes through and attaches to the nut on the other side which has a flat piece on it that locks onto the swing arm.
get a ratchet on it but make sure it doesn't start to turn at the other end.
pretty much what you already know
Old 20-Nov-2005, 13:33   #3
Nattyboy's Avatar
Nice one Keith...Will nip down halfrauds now for an 8mm allen socket (my toolkits shite..still got half of my teknix argos special set left obver from my 16th birthday..)
Nat
Old 20-Nov-2005, 15:03   #4
Nattyboy's Avatar
Did the 9 mile round trip to halfrauds for my new tool..first turn..un******believeable
Im going down the pub !
Nat
Old 20-Nov-2005, 15:07   #5
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
Must be very tight Nat, I got the 8 or so sockets on a rail look similar to one in your pics is that ones u got? Not broke mine yet
Old 20-Nov-2005, 15:30   #6
Mood: Come on spring!!!
Unlucky Nat
If thats the halfords proffesional stuff there supposed to be quite good, if it is they should exchange it!!
Stripped my rear shock out of the track bike a couple of weeks ago and it came out piece of ****!!
Old 20-Nov-2005, 16:18   #7
Nattyboy's Avatar
Your not helping mate !! Yep.halfords professional.
nat
Old 20-Nov-2005, 16:21   #8
keefer's Avatar
if you are not in great need of you allen key you could cut it and put a socket on it.
otherwise I can send you one tomorrow ?
Old 20-Nov-2005, 16:22   #9
aka.eric aka.eric is offline
Heat-do you have a hot air gun?.Often enough to free the buggers.
Old 20-Nov-2005, 17:55   #10
Duke2BSteve Duke2BSteve is offline
Duke2BSteve's Avatar
Also try and tighten more, that sometimes frees it up to loosen, some nuts/bolts actually tighten in the opposite direction to normal (just a suggestion!!) I've got the mother of all socket sets, and tons of allen keys if your interested, am only round the corner...
