Old 20-Nov-2005, 21:14   #1
Andy C Andy C is offline
Drain plugs
Just dropped the engine from the 583 and was pondering how to go about lock wiring the sump plug. The original fits flush against the crank cases. Does someone sell bolt type ones that can be drilled. Any help would be appreciated.
Old 20-Nov-2005, 21:39   #2
Buy a pre-drilled sump plug, oil filler cap and a K&N oil filter which has a pre-drilled nut on the end.
All Ducati sizes are the same.
HTH
Old 20-Nov-2005, 21:44   #3
psychlist's Avatar
Mood: Lucky? For some, maybe!
James (JamColy) drilled my sump plug from the outside face into the drive socket and it works without any problems.
Old 20-Nov-2005, 22:03   #4
domski's Avatar
I used to just drill a hole through the head of the bolt - one way or another.
As long as you can get a piece of wire through it, you'll be ok.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:02.
