Old 23-Nov-2005, 01:26   #1
Scooter916's Avatar
Mood: Hmmm Conference season
Measuring closer shims
Techy ?
When measuring the closer shims do i measure the entire length or from where the 2 collets sit???
glyn
Old 23-Nov-2005, 01:57   #2
monstermob 998's Avatar
what ou have to do on the closers is press the closing rocker down with a screwdriver or similar and measure the gap between the shim and the rocker(making sure the vave is held closed by a wire hook thru the spark plug hole) remember the measurement then take of the wire collets remove the shim and then measure it- if the rocker clearance is greater than thestd clearance then you need a thicker shim there is a calculation to work this out -- i think what you do is subtract the std clearnce from the measured claerance add the measurement of the shimto gain the thickness of the new shim but i aint sure if im right on that-- i got a haynes manual that tells you what what but i havent got it with me if no one turns up that knows better i'll copy it out foryou if its any help-- what engine is it ???
Old 23-Nov-2005, 02:15   #3
sorry mate just re-read and re-read your post -- yes you measure from the collet recess to the base-- not the full length of the shim---least ways that what the ducati workshop manual says and i measured mine that way and the engine aint blown up yet
Old 23-Nov-2005, 09:47   #4
Scooter916's Avatar
Thanks mate.....Out they come again...DOH
Glyn
Old 23-Nov-2005, 10:53   #5
Scooter916's Avatar
You were spot on mate.
I found a handy page that may be of interest to others so here it is http://www.desmoparts.com/ducati/shim/tool.htm
Glyn
Old 23-Nov-2005, 13:11   #6
Tony does some shim measuring tools, shame the pic on his website isn't loading properly
http://www.brancatoengineering.frees...o.uk/900ss.htm
