Old 23-Nov-2005, 22:42   #1
andya andya is offline
andya's Avatar
Discs
Hi
Is there any way of removing the front discs on my Strada from the disc centres. The reason for this is to repaint the centres as it they have some rust spots on them, and as the discs are hardly worn I didnt want to buy new discs.
Andy
Old 24-Nov-2005, 01:27   #2
Jasper Jasper is offline
Jasper's Avatar
You can drill out the bobbins and then replace the bobbins with full floating items.
[Edited on 24-11-2005 by Jasper]
Old 24-Nov-2005, 09:18   #3
Charlie Charlie is offline
Bikes: T8 SP4 / Buell 1125CR
Charlie's Avatar
Floating Discs
Speaking about floating discs anyone know if there should be ..any/none....free/play in the direction of rotation?
TIA
Old 24-Nov-2005, 09:50   #4
yeti yeti is offline
yeti's Avatar
TIA
In principle NO. However, I have been running the "S" on track all season with a small amount of radial float. Intention was to junk the discs at the end of the season. Unfortunately it's the carrier that wears so there's nothing you can do about it.
Old 24-Nov-2005, 12:55   #5
Numpty question...what advantage do fully floatings discs give you?
My standard disc set up on the ST gives me phenomenal stoppers especially now that they're grabbed by P34 calipers.
I need to sort the sponginess of the brakes on my 888, but that's more to do with the master cylinder. Once that's sorted and with some Bendix pads in the calipers I should think they'll be damn near as good.
Can't quite see the need for full floaters, but if anyone can enlighten me?
Old 24-Nov-2005, 13:11   #6
Jasper's Avatar
Basically it stops them warping when they get extremely hot,this is because there is room for the disc to expand on the bobbins.If there was no space at all to expand they would warp immediately.All discs are semi-floating,just that fully floating allows more expansion.
Old 24-Nov-2005, 18:17   #7
Charlie's Avatar
In principle NO. However, I have been running the "S" on track all season with a small amount of radial float. Intention was to junk the discs at the end of the season. Unfortunately it's the carrier that wears so there's nothing you can do about it. [/quote]
Hmmm… thanks for that Yeti, I will have to have a closer inspection I’m sure I can make 2 or 3 mm back/forth movement in line with the discs rotational direction.
Old 25-Nov-2005, 13:28   #8
andya's Avatar
Jasper, where can I get new bobbins?
Old 25-Nov-2005, 13:31   #9
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I got mine from Nelly at Cornerspeed - genuine Brembo ones.
Old 25-Nov-2005, 15:12   #10
andya's Avatar
How easy are they to fit?
