Old 25-Nov-2005, 21:15   #1
icarus icarus is offline
removing 600ss engine for blueprint
My engine is off to Baines racing for a blueprint, mild tune and general TLC soon.
The bloke at Baines told me to be careful when removing it because taking the starter motor off the wrong way will knacker it and a new one is very costly...
Can anyone expand on this please?
Old 25-Nov-2005, 21:20   #2
keefer keefer is offline
keefer's Avatar
cant see why you would have to remove the starter motor to remove the engine
Old 25-Nov-2005, 21:25   #3
you need to remove the LHS engine casing to remove the starter motor. Unless you're planning on this then you'll not be taking the motor off. If you do remove the starter, then there's two bolts internally and one external. Main problem with it can be that the cable from the solenoid can get corroded at the starter connection. When you undo it, make sure the mounting doesn't turn with the nut. It can break the mounting inside the motor, then it get's fiddly.
Only thing I would suggest with the starter in situ is that as you lower the motor out of the frame, be careful the lump doesn't fall on the starter. This would hurt it............
Old 25-Nov-2005, 21:41   #4
Yup - Nelly is da man as usual.
I had exactly this problem when removing my starter motor to get it rebuilt - thankfully I found a guy who could rebuild it and the cable connection onto the starter motor was not too much of a problem after copious soaking with penetrating oil.
I would also of thought you'd be leaving the starter motor on for transport, unless you are trying to cut down on labour time at all?
Curious to know what Baines have offered to do as a Blueprint???
Pistons, con-rods / crank balance or is there more to it than than?
(By co-incidence I was reading a book on Car Engine blue-printing the other day and it got me thinking....)
Cheers - Frank
[Edited on 25-11-2005 by Iconic944ss]
Old 25-Nov-2005, 22:01   #5
Thats what he said...I was on my mobile at work and it was noisy so I had to keep asking him to repeat himself and I felt a bit daft when I didn't hear him properly for the third time.
I hadn't planned on taking it off, so I'll try to keep it on, it looks like its never been off and I don't want to open a can of worms, better let the experts do it.
I told Geoff at Baines I wanted it for purely road riding but because I was used to race bikes and smooth road bikes I wanted the engine to be nice and smooth, properly set up and maybe mildly tuned for just a little more power. As far as I know the engine hasn't had any sort of attention in its 14k miles except normal services, I don't even think its had belts done.
I don't want an unreliable 'supertune', just nice and reliable, super smooth and maybe a bit sharper. Plus I think the whole engine needs an overhaul as it hasn't been touched AFAIK. (it runs perfectly at the moment though).
He suggested I drop it down to them and he'd sort it out. It would require approx 10 hours work and he'd basically strip it completely and check, service and clean everything, including some port work if he thought it was viable.
He said they'd done some desmodue tuning work so I guess they know what they are doing - they come very well recommended.
He also seemed to know his SS's very well and suggested some other mods.
I'm planning on getting my SS well sorted this winter. I was going to get a new bike but I like this one so much I'll stick with it.
Its being professionally sprayed as I type, new suspension next week (from Baines again) and some TLC.
It should be nice for next year.
Old 26-Nov-2005, 19:04   #6
paynep's Avatar
Mood: Wet wet wet
While its apart, have you thought of fitting the 674cc big-bore kit as used by some of us Desmodue racers this year?
It didn't make as much difference top-end as we had hoped but the extra 91cc would add a nice bit of extra torque for the road.
Also I just happen to have one coming up for sale as I'm going back to 583cc for next year.......
Have a word with the Baines bros and let me know if you're interested.
Cheers, Paul
Old 26-Nov-2005, 21:40   #7
You'll need to disconnect the cable to the starter to remove the motor.
If the connection on the starter itself gives you grief, then disconnect it at the solenoid
Old 26-Nov-2005, 22:01   #8
Also I just happen to have one coming up for sale....
.....let me know if you're interested.
Cheers, Paul
I am interested, I was going to ask on here about the big bore kit but I didn't dare because I thought the price of one would make me miserable.
The bike is only worth £1500 and so far I'm spending almost as much again on Gucci bits and engine work. I was considering part-ex'ing it for a fireblade but thought a well sorted 600ss would give me more pleasure than a Jap sewing machine...but theres a limit to the amount of money I want to throw at it.
My original budget was £500 but I'm spending more than that on just the engine and my missus is not best pleased because first of all I promised I'd never have another road bike, then I promised I'd never start tuning this one when I bought it and then I promised I'd only spend £500 tuning it
So after all that waffle...the answer is yes, I am interested but unless I can get hold of one at a price that makes it impossible to resist then I'll have to stick at what I have.
Old 26-Nov-2005, 22:54   #9
paynep's Avatar
Mood: Wet wet wet
You have a U2U
(in case your missus is on line)
Old 27-Nov-2005, 13:52   #10
Blimey....if you're spending £500 tuning a 600 THIS LINK HERE might give you a bigger bang for your buck
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:09.
