Old 01-Dec-2005, 13:14   #1
851neil 851neil is offline
Mood: need a bike...
955 kit for 916SP
I'm in the process of fitting a 955 kit (omega pistons) up to my 916SP motor, and was just wondering if any of you have done this and what I should expect in terms of power torque improvements ?
I've had the crank and pistons balanced as the weight difference was very noticeable and am also thinking of going with big valve gas flowed heads 37 & 31 vs 34 & 30 + 54mm throttle bodies to replace the std 50's.
Any experiences with the big valve/gas flow/throttle body increase ??
Also if you did go down the bigger throttle body route who did you source em from...
cheers
Neil
Old 01-Dec-2005, 14:02   #2
Does THIS help
or THIS?
or THIS LINK HERE
or HERE
Old 01-Dec-2005, 14:47   #3
nahhh, doesn't help at all :P:P
cheers
Neil
Old 01-Dec-2005, 14:58   #4
I've been told my 955 puts out 150bhp, its a Corse engine with just about everything done to it. running 54mm Exhaust and 54mm twin injectors. I have just fitted a starter system to it and hope to have the engine into the rolling chassis over the Xmas break and should be ready for a DSC trackday next year.
Is your the SP3 with the already bored crankcase mouths or have you had them machined.
Old 01-Dec-2005, 15:20   #5
crankcase mouths are already machined, I guess that what I'm looking for now is a source for the 54mm throttle bodies - is there anybody in the UK that remans them to 54mm or is it a case of buying new ??
I'll probably end up going to Jeff Green for my head work.
cheers
Neil
Old 01-Dec-2005, 15:32   #6
As I mentioned mine are twin injector throttle bodies that came with the engine courtesy of Steve Caffyn owner of CSC Racing.
I asked John Hackett about fitting the 54mm shower injectors off my 748RS (also found on a 748R I believe) but he suggested I would be better off sticking with the twin injector setup, maybe because he had already set the the whole package up and done a chip for it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:43.
