Old 01-Dec-2005, 21:30   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Rear brake caliper
Evening Chaps, only just got the 916 through the MOT because the rear brake is sticking, the lever is not returning to its upper position, if that makes sense.
The MOT chap said the brake cylinder may need cleaning out.
Easy job or is it better to buy a new one.
I know some of you boys dont use the bloody thing that much.
Unfortunatley I do from time to time and would like it to work.
Old 01-Dec-2005, 21:36   #2
dst1's Avatar
Doh.. the cyclinder not the Caliper...what a nob
Old 01-Dec-2005, 21:48   #3
Felix Felix is offline
I'd check to make sure the pivot bolt is not corroded. Easy job to undo, remove, clean, grease. Also check the return spring (a coil around the pivot bolt) is not broken.
Old 01-Dec-2005, 22:00   #4
dst1's Avatar
Thanks Felix....
Old 02-Dec-2005, 17:28   #5
Webcore Webcore is offline
Mine did the same - I ended up having to replace the caliper and disc aswell because I kept trying to adjust it instead of replacing the master cylinder. - They're not very expensive - change it before it eats the disc!
Old 02-Dec-2005, 17:38   #6
dst1's Avatar
Ive seen a new master cyclinder for £40 from Ducati Demon on flea bay, might get it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:45.
