Old 07-Sep-2013, 17:02   #1
pguenet pguenet is offline
FS - 998s big bore kit 1038cc, High Comp Pistons + Tuned heads
Selling the top end and big bore kit of my 998 s engine.
The whole engine will be broken up, so please let me know if you are interested in other parts.
(lightened crank, mag cam covers, mag RS side cover, sandcast cases, side covers, slipper clutch, etc.)
I will only keep the Ti rods and the RS gearbox
This lot includes:
- Barrels rebored to 102mm by Kamna in Germany
- High compression Pistal pistons to match
- 998 s heads with full gas flowing by Chris @ CJS racing
- Those also have 749 R cams for higher lift and 749r rockers to match
- Larger 42 mm intake valves
- Different guides
- Racing spark plugs
- Head gasket supplied as is, new ones available from Kamna in 102 bore
This was hardly used at all as I changed my plans after spending thousands getting this work done. Kamna charge EUR 1360 for exchange of barrels and Pistal pistons. Here you get the lot + all the work to match the heads to the bigger bore and higher performance parts in the heads. The engine is good for 160 / 170 bhp at the wheel depending compression level.
Looking for GBP 1,700 for the lot
Chris can be contacted for more information.
Photos below to show how little use this has had.
Old 07-Sep-2013, 17:04   #2
Old 07-Sep-2013, 17:05   #3
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:55.
