Old 03-Dec-2005, 15:04   #1
aka.eric aka.eric is offline
Fuel Tank Problem
Trying to strip the tank ready for painting,problem removing the filler centre.Removed lock ring,removed the 8 grub screws but the centre wont lift out.Is there anything else holding it in?
Old 03-Dec-2005, 18:06   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Nope
Old 03-Dec-2005, 19:35   #3
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
Mine was also really tight. I ended up using a slide hammer (very gently).
Keith
Old 03-Dec-2005, 20:06   #4
The same - tight - I think I ended up putting the centre back in and utilising some of the bolts.
Old 03-Dec-2005, 20:23   #5
andya andya is offline
andya's Avatar
They can be a complete pain in the arse. Put a rag partially through the filler hole (to protect your fingers). Insert two fingers and keep pulling up, working your way around the hole keeping pressure on with your fingers.
Eventually it will come out and nearly smack you in the mouth.
Basically its a matter of overcoming a rubber o ring in a groove
Good luck
[Edited on 3-12-2005 by andya]
Old 03-Dec-2005, 20:52   #6
Thanks for the help,it was tight,thinking Id missed a fastener tight.But its out now!.Not always the tighter the better
Old 04-Dec-2005, 08:54   #7
Rob B's Avatar
Some sort of grease (that doesn't eat the O ring) when you put it back is a good plan. Mine just pops in & out now.
Old 04-Dec-2005, 22:26   #8
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:06.
