Old 10-Dec-2005, 15:11   #1
chicken chicken is offline
chicken's Avatar
Maybe a noddy question
On modern bikes, why does front suspension (forks) have the springs on the inside but rear suspension (shock) have the spring on the outside?
Is it for looks or does one method perform better/different to the other? If it's only looks then why doesn't anyone do an enclosed shock for the rear as it would be easier to clean and might look nicer.
Just wondering like...
Old 10-Dec-2005, 15:18   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
damn good question
Old 10-Dec-2005, 15:25   #3
doogalman's Avatar
Probably cost. And buyers would be wary of something different.
Old 10-Dec-2005, 16:23   #4
Ains. Ains. is offline
Ains.'s Avatar
Mood: He's not happy {:o( He's back at sea!
Springs used to be on the outside on the front pre-1950's.
Same with valve springs they used to be on the outside too at one time.
Asthetics and to stop wear maybe?
Ains.
Old 10-Dec-2005, 16:57   #5
phil_h phil_h is offline
phil_h's Avatar
Its about stiffness and weight - if you want big stiff tubes at the front, its a done-deal to put the spring inside it as it can be smaller/lighter then.
At the back, you can still get shocks with tubes over the springs, but they are heavier.
Old 10-Dec-2005, 19:51   #6
Washboard Washboard is offline
Front and rear suspension on bikes do different jobs, the rear isn't subject to braking forces so the construction can be quite spindly, but on the front, the tubes are relatively massive, so there's plenty of room inside to place the springs out of the way. Those bikes which seperate steering and braking from suspension eg Foale, BMW, Hossack, Yamaha GTS, have solid components for steering and braking, but more dainty items (usually with external springs) for suspension.
Old 10-Dec-2005, 20:16   #7
ericthered40's Avatar
Mood: renegade sexy racer
I hope I don't spend too much of my saturday night thinking about this
No stopped already back on the ****
Old 10-Dec-2005, 22:43   #8
chicken's Avatar
Thanks Phil and Washboard.
So an enclosed rear shock would be over-engineered but would look good right?
Eric, get back to the sauce!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:14.
