Old 11-Dec-2005, 20:20   #1
aka.eric aka.eric is offline
Heat reflective material
The underside of the 888 fuel tank has heat reflective material attached,will need replacing when tanks painted.
Any sources recommended?,expensive from Demon Tweeks etc.
Old 11-Dec-2005, 20:25   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Try Silverstone Factors or Trident at the circuit
Old 12-Dec-2005, 00:27   #3
HW HW is offline
I tihnk I got mine from Demon Tweaks but it's not in their catalogue so phone them. Comes on a roll 2 inch wide. I used it under the race seat unit on the 749.
Old 17-Dec-2005, 12:20   #4
loony888 loony888 is offline
Mood: sensational!!
my painter reused mine with no problems, it's reasonably strong and doesn't tear or distort if removed with care.
Old 18-Dec-2005, 00:04   #5
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Can you use the stuff B&Q sell to fit behind radiators?
Old 18-Dec-2005, 12:11   #6
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
You can also use the flexible mats that B&Q etc sell as a plumbing aid (ie to protect woodwork etc when soldering with a blow torch). They are thin and flexible so can be easily be cut and glued to complex shapes. They are black though.
Keith
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:44.
