Old 12-Dec-2005, 11:59   #1
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
Yoke nut on a 996
Is there a torque setting for the top nut on the yoke, or can you do it as tight as you can, bearing in mind I don't have the correct tool!
Old 12-Dec-2005, 12:05   #2
Harv748 Harv748 is offline
Harv748's Avatar
Do you mean the cap that tightens down on top of the spindle?
If so, then no!, but its not very tight. The idea is to tighten it enough so the bearings are held in place, but not under much pressure.
I haven't got the Haynes book of lies to hand, but it is something along the lines of tighten it to a similar level as you would a spark plug, then actually release it by approx 1/4 of a turn. The end result should be a little bit tighter than hand tight?
Not very scientific I know, but the best I can do.
Old 12-Dec-2005, 12:07   #3
dave996's Avatar
Mood: Fed up...
That'll do for me, cheers Harv.
Picked up most of the bike last Thursday, the frame and swingarm should arrive today.
Old 12-Dec-2005, 12:19   #4
Harv748's Avatar
Piccies please...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:43.
