General Motorcycles only
Old 23-Dec-2005, 12:02   #1
phil_h phil_h is offline
phil_h's Avatar
620/800 instrument panels ?
Anyone got any more info on this ?
The reason I am doing this is because the bike has an integrated instrument panel, ECU and ignition key/lock which are coded together. The bike cannot be run without the original instrument panel which, means I cannot use a race item. If the std item gets mashed in a crash then I'm snookered and can't start or use the bike until a new item is purchased and then coded to match the existing items
Old 23-Dec-2005, 13:12   #2
Other than the real solution is to spend out on a FIM unit but still trying various things on my 620
Old 23-Dec-2005, 13:23   #3
DSC Member AK AK is offline
AK's Avatar
Phil, the way I understand it is: if you have to get the clocks replaced (like under warranty etc) you have to take your existing key (red) to be re-programmed to the new clocks.
It is worth looking for a set of replacement clocks, to keep as 'spares' for just in case.....??
Otherwise, use the keys with that ignition only, as coded to it
I could, as usual be totally talking out of my backside tho
C
Old 23-Dec-2005, 13:29   #4
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
The immobiliser function is just a chip on the circuit board. So hows about... just buy some second hand clocks and in the event of smashing them up just swap the internals over.
Or just disable the immobilier!
Old 23-Dec-2005, 15:00   #5
ericthered40's Avatar
Mood: renegade sexy racer
wanted spare 620 clocks set
Old 23-Dec-2005, 15:30   #6
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
As an electronics engineer I can tell you now that trying to remove a surface mount ic inevitably ends in tears when using a soldering iron or even one with the right solder bit on it. You need to have the right gear otherwise the heat will kill the ic.
Believe me, I've spent lots of effort on this and, as Kev says, the answer is an FIM unit. On my circuit board at least all the indentifying numbers of the ic's have been removed so, even identifying the correct ic is very difficult. I wrote to Marelli and Ducati asking for service info and circuit diagrams but, got no reply at all.
Old 23-Dec-2005, 15:32   #7
C
That's about the top & bottom of it. I'm going to try an experiment with my 2 SS bikes insofar as I am going to put the new bikes clocks on the old bike and see what happens. According the to info I have from John Hackett some bikes will run like this, some won't but, it's a lottery.
Old 23-Dec-2005, 16:35   #8
NBs996's Avatar
twpd... I was thinking of just swapping the whole board rather than trying to take a component off it.
I've had mine apart but can't remember if the board just unplugs or is hard wired to something.
I'd like to try'n disable the immobiliser but it aint my bike!
Old 23-Dec-2005, 16:49   #9
Sorry mate I misread you. Well mine is a plug & play unit - the harness just plugs into it. What I am going to do is rehouse it in a steel box under the seat.
Old 23-Dec-2005, 16:56   #10
butch890 butch890 is offline
Mood: Enjoying Togdom !
From what i understand the codeing isnt activated untill yoiu start the bike using the red key.
We fitted a new clock to Daves bike after his off and it started with no problems.
Butch
